SOURCE: Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
SOURCE: What is a single zone wine cooler?
A single zone wine cooler allows you to store only red/white wine correctly. The cooler has only one temperature control and one space for storing your wines.
SOURCE: I just bought a dual zone wine cooler. What temperatures should I set both compartments to?
Red wine should be stored between 58-68 degrees Fahrenheit and the whites should be cooled at 46-56 degrees.
Koldfront makes a great dual zone cooler. I found you one that holds 18 bottles with
space for 6 bottles of white wine and 12 bottles of red.
There are quite a few
high-end multi-zone wine coolers. I
found you a great 3-zone 143 bottle system.
I must warn you, it is very expensive.
I also had the same indecision and finally I've purchased a dual
zone wine cooler. The dual zone wine cooler allowed me to maintain two distinct
and separated temperature zones within the same cooler which was exactly what
is was looking for, and I think this is the optimal solution for you as well.
Dual zone wine coolers have two temperature controls and the
storage space is divided into two chambers and each chamber has its own
temperature.
Single zone wine coolers have one temperature control and the
storage space is undivided so the whole cooler is at the same temperature.
You need a dual zone wine cooler. They have two temperature controls and the storage space is divided in such a way that each temperature control has its own section inside the cooler; allowing you to store both red and white wines properly.
