I dropped a toothpick down the bathroom sink. It has a permanent push-pull drain plug.I know that it will speed up a hair clog.It is made by American Standard. I don't want to take the elbow apart.- If I raise the plug and turn it shouldn't it come out? and if so, which way do I turn the plug??
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
Posted on Jan 12, 2018
SOURCE: I have the American Standard
Is this in the basement and if yes then you have a brake in the pipe some where because you say that your snake is stopped by cement.
Posted on Dec 18, 2008
SOURCE: american standard bath drain problem
The stoper assembly has linkage and a plumb bob aparatus
Step 1 remove the 2 screws that hold the chrome overflow cover,
Step 2 you will see a wire connected to the up and sown handle
Step 3 you should be able to fish out the linkage which will have a bumb bob attached
mae sure this is all connected if not reattach if you do not see the blumb bob reach your fingers in and grab the wire
Step 4 inspect the linkage the first link is about 3 inches from chrome cove, second is about 8 inches down and final is at the bob itself bob is pointed and slides in by gravity
If this all looks ok then fish it down , put chrome cover on and move lever up and down ( you should see the stopper mve up and down
Step 5 If stopper is not in just insrt in drain hole and move the lver flow lever up and down and drain should work sometimes the stoper does not go up or down far enough there could be an adjustment on the linkage to reduce or increase the length of the linkage
Good Luck
Posted on Jan 01, 2009
SOURCE: I am trying to remove the pop-up drain
To clean the drain simply remove the packing nut off the back of the pop-up assembly. This is located under the sink itself and will be on the back side of the chrome (might be plastic) pipe coming out of the drain hole. This nut is what is holding the rod in place. When you remove it be sure not to lose the ferule (nylon washer) inside. after the nut is off, you can pull the actual stopper out and have better access to the drain inside. Use a small hair remover (you can buy these at the "depot"), it has a long body with small "spines" coming off the sides to catch hair, to pull out hair. It should be long enough to get into the P-Trap. After you are satisfied you can put the stopper back in. Make sure the hole in the bottom of the stopper is lined up to catch the rod. Reassemble the packing nut with ferule and check for leaks. If you want to take the trap off be sure to have some 'pipe dope' on hand to reseal the threads. Teflon tape is not necessary. Reassemble the trap and check for leaks and you should be good to go. Good luck :).
Posted on Mar 21, 2009
SOURCE: clogged sinks and toilets
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
Posted on Apr 13, 2009
SOURCE: Peerless sink plug is clogged with hair. How do I
The plug is held in place by a rod that connects to the plug lever. Look under the sink where this rod enters into the drain. The rod is held in place with a cap that is screwed onto the drain pipe. Unscrew the cap, pull out the rod, and the plug with then lift out.
On some sinks, the plug can be twisted to release it from the plunger rod, you simply twist it until it unhooks. It it does not twist, then folow the first set of directions
Posted on May 02, 2009
Oct 15, 2012 | Plumbing
Feb 12, 2012 | Kohler Plumbing
Nov 29, 2010 | American Standard Swan 4 In. Bathroom...
Sep 17, 2010 | American Standard - Lavatory Faucet -...
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
Jun 20, 2010 | Chicago Faucets CHICAGO FAUCET Mixing...
Nov 23, 2009 | Plumbing
Mar 15, 2009 | Home
Nov 01, 2017 | American Standard Plumbing
166 people viewed this question
