Question about eMachines W3507 PC Desktop
How to update the codec for emachine w3507
I want to update the codec. My dvd player will not play DVDs because the "codec" is old.
Posted by Patrick on
Banjade
  • 430 Answers
Download the Latest Codec HERE
Posted on Aug 14, 2012
1 Related Answer
Anonymous
  • 57 Answers
SOURCE: does my w3507 have an agp port
I found the specs below on their website. Sorry only a PCI Enhanced port, NO AGP. Hope this helps. Best Regards, -md CPU : Intel® Celeron® D Processor 352
(3.20GHz, 512KB L2 cache, 533MHz FSB) Operating System : Genuine Microsoft® Windows® XP Media Center Edition 2005 Monitor : Includes eMachines® 15.4" Widescreen LCD Flat Panel Monitor Chipset : ATI Radeon™ Xpress 200 Memory : 512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB Hard Drive : 120GB HDD (7200rpm, 2MB cache) Optical Drive : 16x Multi-format Dual-layer DVD±RW Media Reader : 9-in-1 Digital Media Manager™ (Memory Stick®, Memory Stick Pro®, MultiMediaCard™, Secure Digital™, CompactFlash®, MicroDrive, SmartMedia, xD-Picture Card™, USB 2.0) Video : ATI Radeon™ X200-based integrated graphics
Up to 128MB of shared video memory
PCI Express (PCIe x16) slot available Sound : 6-channel (5.1) high-definition audio Network : 10/100Mbps integrated Ethernet LAN (RJ-45 port) Modem : 56K ITU v.92-ready Fax/Modem (RJ-11 port) Peripherals : Standard multifunction keyboard, 2-button wheel mouse, amplified stereo speakers (USB powered) Ports/Other : 5 USB 2.0 (1 in front, 4 in back), VGA External Connector, serial port, parallel port, 2 PS/2 ports, 5 audio ports (2 in front, 3 in back) Dimensions : 14.25"H x 7.25"W x 16"D Weight : 22.5 lbs
FYI - PCI Express (Peripheral Component Interconnect Express), officially abbreviated as PCIe (or PCI-E, as it is commonly called), is a computer expansion card standard designed to replace the older PCI, PCI-X, and AGP standards. Introduced by Intel in 2004, PCIe is the latest standard for expansion cards that is available on mainstream
E-machine w3507 specs:
Expandable to 2GB
Weight : 22.5 lbs
Posted on Nov 10, 2009
Where can I go to get an updated codec for my emachines w3507
Hello you can download the vlc player here:
http://www.videolan.org/vlc/
It does play dvd you can even record a clip of your favorite movie
Click on show and select advanced controls when the program is installed
And here is a free burner:
http://cdburnerxp.se/
I use this codec:
http://www.codecguide.com/
Good luck
Aug 14, 2012 | eMachines W3507 PC Desktop
Wont play dvd
You might need some codec files installing to play specific file formats.
Search google for free codecs. Like this:Codecs
Jan 31, 2012 | HEWLETT-PACKARD Elitebook 8460P
I HAVE DVD ROM BUT I CAN PLAY DVD MOVIES WHEN I CAN PLAY THE MEDIA PLAYER DAID I HAVE TO UPDATE MY VGA DRIVERS
You have to get codecs before you can't play DVDs.You can get them free at www.filehippo.com.Get the codecs pack install it then your Media player should then play DVD movies.
Jan 21, 2011 | Dell OptiPlex GX270 PC Desktop
I CAN NOT RUN DVDS ON IT this is what it says Windows Media Player cannot play the DVD because a compatible DVD decoder is not installed on your computer. I asked for this dvd drive because i want...
Hello ,
This is your old DVD ROM ,it the problem of your firmware.To read new DVD, needs updated software which is install in new DVD rw .Or if you played some DVD which can not read now,just roll back the driver or install vlc media player.
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx
Hope it will help you.
Dec 26, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My a60 plays some dvds and not others - why?? I am not using rental copies!!!
are there any common characteristics of the dvds it won't play? Use this link to download and update your codecs.
http://www.codecguide.com/download_kl.htm
Codec stands for encoder/decoder keys which basically instructs the computer and the media player how to properly record and playback media correctly.
Now that your codecs are updated, see if the problem continues. If the issue persists, (i am assuming you already checked the surface area of the dvds to see if they were dirty, scratched or damaged) then double check the specs on acer's website to see the compatibility limitations on the player. not all dvds are created equal my friend... newer video compressions, track layering, and hi-def technologys may be beyond the capabilities of your laptops current device. the good news is, upgrading the optical dvd drive to work with the latest innovations is not difficult and its not going to set you back.
let me know what happens - if i was able to fix-ya, let us know by submitting your feedack.
Aug 12, 2009 | Toshiba Satellite A60 Notebook
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
DVDs will not play on drive(DRW-1608P3S)
The reason for this issue is the lack of a codec software like Cyberlink PowerDVD or PowerCinema.These are paid versions.We could try installing a codec pack from Klite.Its free.The link is : http://www.free-codecs.com/download_soft.php?d=5075&s=775 Please let me know whether it fixed it
Mar 17, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
No sound when playing dvds
This is very likely a codec problem. A codec is a software component used with video and audio players that translates the electronic media file into something that can be displayed. Most of the time, the video codec will be out of date and you'll hear the audio but not see any video. You've got the reverse problem, obviously.
Unfortunately, Microsoft does not make this easy. Even the latest download of codecs from Microsoft doesn't necessarily update the Windows Media Player to play any DVD. You will need to do a codec search and download the latest. Last time I checked, 'download.com' had them available (this is CNet's download website). Good luck!
Dec 30, 2008 | Computers & Internet
I have reinstalled my computer. the duilt in dvd player does not work. it says you have no decoder. I downloaded the dvd driver from emachine site. it does not make any difference. please give me a link to...
Download and install the K-Lite codec pack and you should be able to play DVDs in Media player
http://www.free-codecs.com/download/k_lite_Mega_Codec_Pack.htm
You can also try downloading a dedicated DVD player like this one:
http://www.download.com/AVS-DVD-Player/3000-7970_4-10491860.html?cdlPid=10842663
Jun 14, 2008 | E-Machines Computers & Internet
eMachines W3507  PC Desktop Logo
63 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
