Question about Cats
I have three cats. Will two litter boxes be enough or do I need more?
Posted by joyce on
doreen
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
The general rule of thumb in regards to litter box quantity is one plus one - one litter box per cat plus one extra.
Posted on Aug 14, 2012
What is the best litter box for my kitty?
Little kittens require a litter box with sides low enough for them to get in and out easily. You should visit http://www.shopzilla.com/cat-supplies/litter+boxes/31000200/products and you should find the right litter box for your kitty.
Aug 15, 2012 | Cats
Tip
Training you cat to use a litter box
For the most part, learning to use a litter box is instinctive for cats; however sometimes they may need a little extra coaching along the way. The following are some tips to help you train your cat to using a litter box successfully.
• Place your cat in the litter box after every nap, meal, play session or any other time your cat appears inclined to relieve itself
• While litter box training try leaving a small amount of waste in the litter box so the scent can act as a reminder to your cat as to what the box is for
• Find a good location - away from high traffic areas; preferably somewhere your cat can access at any time of day/night
• Do not place the litter box near your cats food or water
• Never punish your cat for having an accident outside the litter box. Instead I recommend firmly saying NO and then placing your cat in their litter box and praising them. This way they will begin to associate positive reinforcement with the litter box as opposed to negative associations.
• If you have multiple cats, you should have multiple litter boxes. Like us, cats want their privacy too
on Aug 28, 2012 | Cats
What are the advantages of covered litter box?
Covered litter boxes prevent stains on walls from cats that usually stand up to ***** and scattering of litter by cats that scratch excessively inside the litter box.
Aug 15, 2012 | Cats
My dog keeps eating the litter out of my cats litter box. What can I do to put an end to this?
There are a few things you can do to prevent your dog from being attracted to your cats litter box. First and foremost, you should try to remove your cats waste as quickly as possible. You can also try sprinkling some meat tenderizer onto your cats food before ingestion. This will help make the smell of your cats ***** less enticing to your dog. Lastly, I would recommend placing your cats litter box somewhere that your dog cannot reach it; possibly by raising the litter box or placing it in a room only accessible through a small cat door.
Aug 14, 2012 | Cats
Why is clumping cat litter better than clay litter?
Neither one is better than the other, they are based on preference. More people prefer to use clumping cat litter. Although clay litter is cheaper and absorbs well, clumping cat litter offers more advantages in my opinion. Clumping cat litter is much friendlier to the environment, seeing as you do not need to throw away the whole litter box every time your cat releases waste. It is easy to dispose of your cats waste products and helps to diminish the amount of odors.
Aug 14, 2012 | Cats
Why is the height of a litter box important?
You want your cat to be able to get in and out of the box with ease, but high enough to keep the litter from going everywhere. The average height for litter boxes is 6 inches; however you will need a lower litter box for seniors and perhaps kittens as well.
Aug 14, 2012 | Cats
How much litter should I put in the litter box?
You should have enough litter to allow your cat to easily cover any waste it leaves behind. Make sure that there is enough so that they don't feel the bottom of the litter box. You should give your cat a minimum of a 2 inch base of litter in the box.
Aug 14, 2012 | Cats
They have stopped making the brand of litter I have always bought for my cats litter box so I will need to find a new one. I have been told that cats do not adapt well to new litter. What can I do to...
I would recommend adding a small amount of the new litter in with the older product. Slowly you can start adding more and more newer product to the litter box until your cat receives the change without any problems.
Aug 14, 2012 | Cats
My cat has suddenly stopped using his litter box. Why would this be? How can I get him to return to the litter box?
Is there any chance you have recently switched brands of litter? Cats can be extremely particular when it comes to what kind of litter you put in their litter box. If you find one that works, you should stick with it. No need to fix something that isn't broken.
Aug 14, 2012 | Cats
Cats Logo
118 people viewed this question
Top Cats Experts
Ruth summersides
Tom Chichester
David Payne - Geek
David Payne - Geek
Are you a Cat Expert? Answer questions, earn points and help others
