Washing Machines Logo
Anonymous Posted on Aug 14, 2012
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
My Simpson Ezi Sensor 5.5kg Front Loader keeps pausing in the middle of washes. It won't complete a wash cycle no matter how many times I unpause it, it just pauses again some time later. Also the detergent never goes through to the washing machine, it just stays in the detergent loading part. Please help!
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2627
Points
7
You might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
  • Anonymous Aug 14, 2012
    I've checked the manual and am putting the detergent in the correct part of the dispenser. The machine fills up all right but seems to be just pausing in the middle of the cycle and not emptying. The filter is fine, but I'll have a look at the hoses and valves if I can find where they are. Thanks!
Adriana Torres
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 26, 2013
Adriana Torres
Contributor
Level 1:
Answers
Questions
0
Helped
2220
Points
0
Did you find out how to fix it, Im having the same problem!
2 Related Answers
Anonymous
  • Posted on Mar 11, 2010
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
Anonymous
  • 6277 Answers
  • Posted on May 12, 2011
SOURCE: I just got new Simpson
NO- you are not going too fast for the machine! As you say that the second load contained WOOL blankets it is possible that the drain filter has become blocked - yes, already.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
MANUAL
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Simpson Ezi Set 7kg Front Load Washing Machine SWF7025EQWA 9315540408058
Press and hold the start button for 5 seconds. The child lock is on.
My door handle has snapped off my simpson ezi sensor front loader , how do I open it until I gets repaired ?
Put your question in the washing machine section
This is only a chat room
No one home at FixYa-- just a free website
No guarantee you will get an answer
2helpful
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
7helpful
3answers
3helpful
Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
2helpful
2answers
Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Top Simpson Washing Machines Experts
vince
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
