Question about Lexar JumpDrive S70 - USB flash drive - 8 GB
Lexar JumpDrive S70 - USB Flash Drive - 8 GB disconnect
Everythime it moves while plugged in it disconnects
Posted by gter on
Brian Sullivan
  • Lexar Master
  • 27,725 Answers
This could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driver
if you motherboard came with a disk the drivers could be on it
otherwise you might need to download them
or a bad dusty or loose usb lead connection
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Posted on Aug 14, 2012
What can cause my 1996 mercury villager to cut off everythime i put it in drive
Neutral Safety Switch
Transmission Gear Position Switch
There are others, but they would be more
along the lines of a major problem
Oct 30, 2014 | 1996 Mercury Villager
Power steering pump noise
  • Did you cap the system when you disconnected, and what type of fluid did you use. Several things would make this happen 1. You overfilled the reservoir when you replaced it with the hose 2. Air became trapped in the steering system upon replacement 3. Bad steering pump is not pulling fluid from the reservoir, but pushing fluid into the reservoir when you turn. I would say there is air in the system since you opened the system to make a repair. Either one of these problems can damage other components, so I hope you get this fixed sooner than later. Good luck!
Jul 13, 2014 | 2004 Chrysler Pacifica
I keep getting error message E004-0002 ( Switch off and on again) everythime I switch on my canon clc 1000
E004 is a temperature related error. You would need to call in a service technician as it will require replacement parts.
Sep 12, 2011 | Canon CLC 1000 Color Copier
The radiator has one holding bolt at the top and rubber mounted grommet at the bottom. Removal of the top bolt enables the radiator to swing forward but cannot be moved out of the way to get to the spark...
I use a SnapOn Universal joint coupling Plug spanner. With that, I can get in at odd angles.
Method.
Be careful not to damage the oil cooler and radiator fins!
Remove, Lower and upper cowl and wind guard.
Remove oil cooler upper mounting bolts and wire harness guide.
Disconnect fan motor sub harness (2 pin) and remove radiator upper mount bolt.
Remove the radiator from the upper and lower brackets by moving it to the left, then move the oil cooler forward as an assembly.
Remove the air guide from the oil cooler bracket and cylinder head cover.
Disconnect the spark plug caps.
Clean the area with compressed air to ensure no debris enters the engine.
Remove the plugs and check/clean/set/replace.
Jan 08, 2011 | Honda CBR 1100 XX Super blackbird...
Paper jams in the same spot everythime
Sorry, but that means you have a failing printer. Either something is broken, or amiss, or malfunctioning in that device, and you need to get it serviced or replaced.
Oct 26, 2009 | Dell 1720dn Laser Printer
Bebo wont work
Thats because the bebo site has crashed and they are trying to fix the problem. sorry for the inconvenience
Jun 28, 2009 | Bandai Digital Entertainment Cowboy Bebop
Lexar JumpDrive S70 - USB flash drive - 8 GB Logo
421 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
Harrie
john smith
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
