Find a new AC engineer approved by LG. All AC Units leak a small amount at the compressor bearings and seals. It sounds like yours needs some sealant. and gas, or a new sensor. Diagnosis by an LG trained engineer is needed.
According to the manufacture this unit never needs draining it vaporizes the liguid.
If it were to have a water tank it would be in the bottom of the unit and you can see the level in the tank, on models that have a tank they simply pull out and remove to be drained.
Product Description
The compact NanoMax AC takes up little room in the interior environment, and features the patented AutoDrain NanoMist Technology that vaporizes excess fluid build up, eliminating the need to drain the unit. The NanoMax AC has integral handle and casters for transporting unit, and long lasting washable filters. Offered in designer colors with remote control, this attractive appliance features outstanding industrial design that blends harmoniously with today interiors. Power Supply 115 V / 60Hz Power Consumption Range 680 - 830 Watts Current Range 6.8 - 7.9A Dehumidification Range 42 - 50 Pints/24H Refrigerant R22 Compressor Rotary 2 Fan Speeds 1-12 Hr Timer LED Screen Auto Shut Off Thermostat Range 62-90 Degrees F Dimensions - 12 W x 15 D x 30 H Weight - 50 lbs.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers for spare parts, as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
Do you live in Canada? If so, you can pick up AC do it yourself recharge kits at Canadian Tire. If you don't they may also be available where you live. Check your local auto supply store fof availability.
1.2 amps, 115 volts 60hz 1550 RPM; Shaft 1/4" x 1" Rotation = CCW 3.3" Diameter Motor 2 Mounting Studs Opposite Shaft End Motor Case Length 1 15/16" 2-Prong 115 Volt plug For Model 8663RP, 8673RP 8664RP (86933-000) 86933000, JA2B104N, JA2B104 can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
you cant change to a different gas without changing the compressor oil...they have different properties that dont mix with other gasses... in some cases the compressor also needs changing
