Question about Samsung HL-R6167W TV
Samsung HLR6167W no picture/no sound
I have a Samsung HL-R6167W TV that made a loud pop this weekend, and the picture and sound went out. Only way I could shut it off was by unplugging it. I replaced the bulb in it, and it still has no picture or sound. Plugged it back in, and it turned on instantly without me touching the power buttons. I don't want to sink a bunch of money into a 7 year old tv.
richie46
    Top Expert:
  • Samsung Master
  • 12,962 Answers
So don't. Just retire the set and move on with a newer cheaper better set with warranty.
Posted on Sep 13, 2017
1 Related Answer
Anonymous
  • 58 Answers
SOURCE: TV made a crack-pop sound and then the picture-Samsung HL-R6167W
sounds like you need a new lamp
Posted on Jul 15, 2009
2answers
My samsung hlr6167w will not power up. It sounds as though the lamp is trying to strike, however it never does come up on a picture. After several minutes, all three lights on the front power cirle (Lamp,...
All three LED lights flashes,u hear alot of clicking sounds too?Yes,ur tv the Ballast board is dead too.This Ballast board job is only to ignite the tv projection lamp only.Replace the Ballast board,should solve this problems.
I was watching tv then heard a loud crashing or smashing sound, then the tv went black. Now there is no picture and the lamp light on the front of the tv keep blinking.
Sounds like your color wheel is busted...
This was not an expensive part nor too much of a complicated process on my hl-r5067w (see here: http://mistermarbles.blogspot.com/2008/04/replacing-color-wheel-for-samsung-hl.html), but you'll need to figure out part source and process differences on yours.
4helpful
Problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
2answers
Samsung Model HLR6167W
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
2answers
Samsung HL-R6167W TV Logo
Ekse
Demonic-2011
Demonic-2011
