I have a mini refrigerator that I plugged in for the first time, and it is not working. The "wonderful" customer service told me it sounds like it needs a replacement box? The manufacturer's warranty requires me to ship it back at my own expense (both ways) and the separate company extended warranty advised that they don't cover anything until after the first year manufacturer's warranty. Easy solution? Would it be better/cheaper to call a local service tech?
First make sure that the plug is working that is supplting the power, plug in a light to test. If it is then it may be a fuse in the electrics of the unit, replace if it is broken. If u can not easily find this then take it to a repair shop. If it is not the fuse then a repair shop is yr only option.
SOURCE: Admiral Refrigerator Model HMG671581 bought from Montgomery Ward 9 years ago.
Thanks for the chat
I really belive after 20 years of service on home appliances this is the problem with your unit. If you call a repair company to come out and it is not the issue (dirty Condenser ) I will refund your money on this chat.. Sound fair?? my email is [email protected] please email me and let me know...Have a great day
SOURCE: clicking noise-GSH22JFR/SH200106
November 7, 2006
Dear GE Customer Care Servicers,
GE Consumer & Industrial places a very high priority on product quality and customer satisfaction
and thus continuously assesses our product reliability. Recent analysis has discovered a potential
problem with the main circuit board on a limited number of refrigerator models, which could lead
to lower than anticipated life expectancy on that component. Therefore, if the main circuit
board fails, GE Consumer & Industrial will replace this part free of charge to the consumer until
further notice.
Models Covered: see attachment
The models affected are side-by-side plastic liner, side-by-side metal liner, bottom freezer two
door and bottom freezer French door. The models were produced between May 2005 and August
2006 (HH – RL serial range) and are included in this program. See enclosed list.
Potential Additional Covered Parts:
Specific parts involving the failure of the main board are included in this program. These parts
are limited to the following:
-Evaporator Fan failure, only if accompanied by a Main Board failure
-Dispenser Board failure, only if accompanied by a Main Board failure
The main board part number in cases in WR55X10552. Please use your normal warranty MA00 job
code for this repair. If you encounter an evaporator fan or dispenser board failure due to the
above main board, please include on your invoice and use the normal MA00 job code. It is critical
that you verify the proper functioning of the unit including the evaporator fan motor and
dispenser board before leaving the home to avoid a repeat call.
Units may be in or out of the standard 1-year product warranty and both instances are covered
under this concession program.
If you previously completed this repair and charged the consumer, please send a copy of the
service invoice to General Electric Consumer Relations, PO Box 10736, Norfolk, VA 23513 or fax a
copy to 1-877-299-0725 so that we may issue a refund to the consumer.
Sincerely,
Richard Zutterman
SOURCE: GE refrigerator not cold enough, again!
I emptied the freezer, unscrewed the freezer floor, pushed it out of the way, and saw the ice, just like last time. So I poured hot water over the ice, made sure the ice was all melted, even from below (under refrigerator), and put the floor back in - works fine, for now!
SOURCE: Amana refrigerator too warm, freezer too cold
the damper control is not working let me tell you what to do the air that comes from the freezer block if you can get to the damper you will see it have a get rool a piece of paper between the body of damper and the get flap and have it open if the refrigerator side start cooling is the damper control i am sure about that is the damper control
SOURCE: 9 year old Kenmore refrigerator is making a lound noise
if you are handy you get the model# of the refrigerator if is the fan in freezer you can change it you have to know were the noise comming from
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
