Panasonic Lumix DMC-FZ20 Digital Camera Logo
Posted on Aug 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have panasonic Lumix DMC-FZ20 and when I start camera on the display it come with message "plz turn camera off and then on again." But it dont really do anything when restart occurs. It keep showing same message. Although it allow me to see old pics when started with play mode but dont start if the message has already on display. Moreover, when this message is on it wont allow me to work with any of the camera function including zoom in/out. . . Many Thanks . . .
Anonymous
Level 3:
  • Panasonic Master 6,771 Answers
  • Posted on Aug 14, 2012
Anonymous
Panasonic Master
Level 3:
Answers
6771
Questions
0
Helped
1777273
Points
21413
Usually when this message pops up it indicates the lens position is jammed, you will need a camera technician to assess the item for repair cost.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 14, 2008
SOURCE: My panasonic lumix dmc-lz7 camera
battery might be weak and needs a replacement or there is improper shutting down.
Anonymous
  • Posted on Jun 18, 2009
SOURCE: Panasonic Lumix camera, DMC FS5
I had same problem. I just got the camera working again. Not sure how it exactly happened but while I had it on and it was zooming in and out, I changed the mode and tried to take a pic. It would ask me to turn off and on again which I would do quickly and change the mode to something else like "portrait" or "landscape", etc. and try to take a pic. After a few times it stopped and focused on something. So not very scientific but doing that must have kicked it in the head or something.
alfa104
Henk de Ruiter
  • 80 Answers
  • Posted on Jun 20, 2009
SOURCE: have Panasonic Lumix DMC-TZ5. get message turn camera off
Did you drop the camera on the lens?
You have to replace the barrel (cost around 175,00 euro)
try to find a cheap second hand camera en replace the lens unit...
Anonymous
  • 83 Answers
  • Posted on Nov 05, 2009
SOURCE: I have a Lumix DMC FX3..great butr is stuck in
Hmm, looks like the zoom rocker switch might be stuck. To get to the switch you'll need to partially strip the camera. This is a bit fiddly, but should be ok if you are comfortable with taking things apart. I repair cameras as a hobby and in my opinion lumix-es are by far the easiest to take apart and put together.
Remove the battery, unscrew all the screw holding the case making notes which screw goes where (they are not the same). Very carefully lift the back of the case to see two white ribbon cables going to LCD screen. Disconnect them. Once done, remove the front of the case. With both case panels removed pull off the top section (where the power, shutter/zoom buttons sit). This will require a bit of force. Once done, you'll need to undo the plastic cover, there should be a screw or plastic catches holding it onto the small logic board. A word of warning, there is a flash capacitor attached to the board (looks like an AAA battery). This can potentially electrocute you (won't kill you but is not very pleasant) , so try not to touch the tracks/connections on the board. Once you expose the top of the board you'll be able to see the zoom rocker switch (a little silver square thingy with a black bit sticking out). The black bit is the bit which is stuck. Try to move it (gently). It should stay in centre position. Well, that's it. Put the camera together and hopefully it's back to normal.
Hope this helps.
Raf
Anonymous
  • 3006 Answers
  • Posted on Nov 28, 2009
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
3helpful
I have a panasonic lumix DMC-FZ20 camera that i installed an 8g memory card but it says memory card error
The DMC-FZ20 works with MMC and SD cards, 2GB or smaller. Your 8GB card is an SDHC card, which fits into the slot but is electronically incompatible.
Can I use a panasonic lumix dmc-fz20 as webcam
Sorry, no. The DMC-FZ20 is designed to store images and videos to memory, not to stream live video to another device.
Problems with windows xp - no icons on desktop when inserting the Panasonic Lumix DMC-FZ20 camera.
Having gone over five months without a response, I assume my suggestion to use a card reader solved the problem.
1helpful
4answers
I need instruction booklet for Panasonic Lumix DMC-FZ20 12X 35mm equivalent.
You can download the required manual by clicking the link below:
http://panasonic.com.au/content/library/files/F000741.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
How to charge the camera
Hope you got the battery charger with the camera kit. Use it to charge the battery.
Dust inside lense
Open the Lens Assembly and clean it but do it, in case you know how to do it.
Lumix / Panasonic fixed lens Digital SLR problem.
try to help the lens come out by pulling it very very lightly...you should here a pop.
1helpful
The lens can not move due to an obstruction.
Gently put some force on the lens, turn the camera on and it works.
Best regards from Holland!
www.SemafoonWinkel.nl
2answers
The memory card has a small slide lock on it. It may have been inadvertantly locked. Just slide the lock to the other position and try card again.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
