Question about Sony KP-43T90 43" Rear Projection Television
Sony Tv will not power on. - Sony KP-43T90 43" Rear Projection Television
Where can I find a A1300319A Board. Because the tech took the board out, and said something wrong with the board.
It is a Power Supply board and is a part shared with some Sony televisions.
Sony Power Supply Board A1300319A KV32HS500 ... - eBay
www.ebay.com > ... > TV Boards, Parts & Components Sony Power Supply Board, A1300319A, KV32HS500, KV34XBR800... (280925870381) in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio ...
Sony A1300319A SONY A-1300-319-A COMPLETE PC D ...
www.amazon.com/Sony-A1300319A-A-1300-319-A...BOARD/.../B001... THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONY TELEVISIONS. PLEASE FOLLOW THE LINK ABOVE FOR ...
Sony A-1300-319-A D Board, Complete - Encompass Parts
https://www.encompassparts.com/.../Sony/A-1300-319-A/D_Board,_Co... Image, Manufacturer, Part Number, Description, In Stock, Part Price. Pts Modules, A-1300-319-A, Sony - D Board (Deflection & Power), 271.90 ...
A1300319A, A-1300-319-A Sony TV Module, D
www.tristatemodule.com/A1300319A-A-1300-319-A-Sony.../a1300319... US$148.00 Part Number: A1300319A. Board Numbers: . TV Models: KV-32HS500, ... Home > TV Parts > PC Board > A1300319A, A-1300-319-A Sony TV Module, D ...
Jan 30, 2016 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Wega tv
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Triniton not powering on
If the lights don't come on the tv ,try to connect the tv to the other power point
and check if it powers on, if its does not power on then its the problem with
fuse inside the tv replace the fuse and check its works ...and also test the power chord for continuity ..
Good luck...
Feb 18, 2009 | Sony KV-27FV16 TV
[email protected]
Accroding to your model number:(KV-...) In sony tv units power supply porblems is very low unless a power surge.
You have to check these things.
1. Stand by 5V available or not
2.If stand by 5V available press power and check B+ is getting or not
3.If B+ available check Horzontal oscillation
4.May be H-out transistor or video amplifier is bad.
Oct 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
SONY TV WON'T POWER UP WHEN COLD.
as there is a problem of any electrolytic cap in tv as per what you say. but in my opinion it might be taking time to crt glow due to low supply or its ageing.
Sep 22, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony KP-43T90 43" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
