Question about Sunpak Auto 555 TTL Flash
Using a Sunpak 555 with Cybersync transmitters with a canon 40D off camera and getting inconsistent firing
Using Energizer 2300 mAh fully charged batteries. Fires normal and consistent a few times then it does what it wants to.
Posted by Ryan on
jpledger10
    New Friend:
Did you find a solution? ive experienced a similiar problem. i think i might need to buy new flashes.
Posted on Nov 08, 2012
5 Related Answers
kalaci
Laszlo Kalmar
  • 30 Answers
SOURCE: Sunpack 555 inconsistantly fires with Pentax K20
Your strobe is faulty and needs repair at a trained service center. The actual culprit may be the voltage converter circuit that supplies the high voltage to the flash capacitor, or the voltage divider that drives the ready lamp and, at the same time, makes triggering possible.
Posted on Feb 18, 2009
Anonymous
  • 4 Answers
SOURCE: Sunpak ring flash problem
I had a DX-12R for some time several years ago until it was stolen. I loved it. I recently purchased a used 8R and it is fine but I still like the 12R better. Especially the preview light feature. Ok. Make sure the batteries are all good, one bad apple does spoil the whole bunch. Check your cord connections and finally make sure the hot shoe connection is clean. That last one was usually the culprit when I had problems. Note that your hot shoe on your camera could also be going bad. I had a Ricoh that did that, I thought it was the flash. Good luck.
Posted on Sep 18, 2009
Anonymous
SOURCE: I have a Sunpak PZ42X for Canon and a Canon T1i.
I have the same problem and i dont have a idea to solve it. Did you do something?
Posted on Feb 26, 2010
bhargav
  • 66 Answers
SOURCE: Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Posted on Mar 05, 2010
bhargav
  • 66 Answers
SOURCE: Sunpak 622 Recycle Time w/ Batteries vs AD-26
I have made Nimh pack which has 2900MAH cells and is very fast recycling.But beware that it will heat up Xenon(it needs cool down time before you fire full power repeatedly.Also its capacitor will be short life due to electrolytic(Same as fast battery chargers ruins the battery life).
And when its production is seized,I care it more.
Posted on Mar 30, 2010
1helpful
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
1helpful
2answers
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Can I use re-chargeable 2500 mAh batteries with Sunpak PZ 4000?
Yes, you can use Ni-mAh re-chargeable batteries with Sunpak Pz 4000
Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
1helpful
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Sunpak 555 keeps flashing on it's own
Test button pins shorted to ground.
Could also be center pin shorted to ground.
[email protected]
Sunpak Auto 555 TTL Flash Logo
Top Sunpak Cameras Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
