Question about Krups Small Appliances Espresso Machine
Error code 05 appeared on my coffee machine xp7240, what happened?
Posted by Diana Choo on
  • Diana Choo
    Diana Choo Aug 13, 2012
    Your can change the pump, seal  & vale part no ms5370777 this will help. Good Luck.Joseph
Ross Keen
  • Krups Master
  • 1,364 Answers
Error 05 I would normally associate with a distributor problem,
New distributor
New barista seal
New tamping piston seals
New tank seal
It is not a job for the faint hearted.
Posted on Aug 29, 2018
4 Related Answers
leethedeuce
Lee A.
  • 4472 Answers
SOURCE: Krups XP7240 - leaking
First off how long have you owned the unit and when did this problem develop. Once I have more information I can assist you further.
Thanks,
Lee
Posted on Oct 13, 2008
Anonymous
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
espressonist
espressonist
  • 1711 Answers
SOURCE: I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
Posted on May 10, 2010
paul_on_trav
  • 17 Answers
SOURCE: Hi, I have an XP7240 and recently i only half a
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. It's a lot of work but if you're handy you can get to the valve on the bottom of the machine. I have the same problem but haven't looked up the replacement part (can be expensive). Good luck!
Posted on Aug 07, 2010
Krups ea 8250 error code 05
I have ea8250 krups machine . It gives me error code 05
Jul 29, 2014 | Krups Coffee Makers & Espresso Machines
My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 1003380 Accademia Espresso Machine
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
May 10, 2010 | Krups Small Appliances Espresso Machine
Jun 06, 2009 | Krups XP4030 Espresso Machine
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Machine Fault Error No 06 at start up Model is Krups XP7240 Expresso - not listed in product list
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
Jul 10, 2008 | Krups XP4030 Espresso Machine
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Small Appliances Espresso Machine Logo
1,423 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
