The he2 Kenmore dryer having a problem it is flashing a F at us, when the clothes are done and they come out really hot. I have no idea what this means.
SOURCE: Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Posted on Jan 24, 2009
SOURCE: f-26 error message
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
Posted on Mar 06, 2009
SOURCE: Kenmore HE2 flashing lights
I had the same problem with it stopping mid cycle and lights flashing. Turns out all i needed to do was clean out the very clogged drain pump filter. it is located just behind the front kick panel. it unscrews and pulls right out. there was a nasty accumulation there. ran great afterwards.
Posted on May 11, 2009
SOURCE: Kenmore HE2 Dryer Does Not Autmatically Shut Off
We need the error code # please
Posted on May 12, 2009
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
Oct 11, 2016 | Kenmore Dryers
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Sep 19, 2011 | GE DVL223EBWW Electric Dryer
May 30, 2011 | Kenmore Dryers
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Sep 15, 2009 | Dryers
Aug 18, 2009 | Roper RES7646KQ Electric Dryer
Jan 14, 2009 | Kenmore HE2 Plus Front Load Washer
May 05, 2008 | Kenmore 85871 Electric Dryer
402 people viewed this question
