Question about Champion 3500/4000 Watt Portable Generator
Champion 3500 generator will not start. Removed old gas and added new. Changed the spark plug,nothing. Sprayed starter fluig on choke got a quick start, but will not stay running
Posted by Jack Teague on
  • Brandon Murphy Aug 31, 2012
    This is in the wrong section.
  • Frank Bayait
    Frank Bayait Nov 11, 2012
    May need valve adjustment
3 Related Answers
John Bond
  • 101 Answers
SOURCE: Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Posted on Aug 02, 2012
W. E. Walters
  • 3 Answers
SOURCE: My Champion generator seems to be getting gas mixed into the oil. Also, it wont carry the load when plugged into my compressor.
Bad rings or cracked head
Posted on Aug 20, 2012
markhandyman
markhandyman
  • 44 Answers
SOURCE: i bought a champion generator 2 yrs ago.It ran when I bought it. Have not occasion to use it until now. It will not fire. It had some rust on the flywheel. Removed the rust. I replaced the spark plug.
Probably only one of these issues to cause that. gas not turned on or flooded- ck spark plug to see if it is wet, check to see if the spark plug is getting power by taking it out leaving the wire on it and holding it about a 1/8 of a inch away from some exposed metal part of the frame and have someone try to start it. if you get a spark then ck your gap and put it back. Ck your choke too to see if it is on. also if it was flooded then leave the choke off and keep trying to start it. if it was stored outside, it may have water in the gas.
Posted on Oct 28, 2012
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
Yamaha dt 175
try a new spark plug
If you need further help, I’m available over the phone at https://www.6ya.com/expert/lee_9bf2e1a3cef596dc
Oct 02, 2017 | Watches
Champion 3500 generator how to fix stuck float
It could be a carburetor problem or it may be the low oil cut off switch. Check to make sure oil level is up. If it is check the needle valve attached to the float and the seat. The old carbs used to have a brass seat. Some of the new carbs have a rubber seat and it may need to be replaced. Hope this helps.
Dec 31, 2013 | Champion 3500/4000 Watt Portable Generator
Only runs with choke
There is an air leak in the seals somewhere between the carb and the intake manifold. You are getting too much air! ALL of those seals need to be changed, As the paper seals age they develop small cracks that kill the vacuum made by the engine to pull in the gas/air mixture!
Dec 23, 2012 | Champion International Champion Power...
I bought a champion generator 2 yrs ago.It ran when I bought it. Have not occasion to use it until now. It will not fire. It had some rust on the flywheel. Removed the rust. I replaced the spark plug.
Oct 27, 2012 | Champion 3500/4000 Watt Portable Generator
Won't start. changed gas. oil is okay. added fuel additive. new spark plug.
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Loosen bolt on float bowl. Fuel should start leaking from around top rim of bowl, if it doesn't then there is a restriction somewhere in fuel line or float valve is blocked in bowl.
Feb 21, 2011 | Coleman Powermate Premium Plus 6250W...
Generator won't start
i have the same problem. i took out the air filter and sprayed tb into it and it ran and died. this is the only way to get it to fire up.
i took off the carb, dissasembled it and blasted it out with tb cleaner, took out the jets too, put it all back and it still does the same thing. it is getting fuel but it won't run.
need a profesional answer on this one please.
thanks, tom.
Jun 13, 2009 | Yamaha 1,000 Watt Portable Generator...
Champion 3500/4000 Watt Portable Generator Logo
623 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
