Handset says "silent mode on", I can not figure out how to turn it off.
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
SOURCE: Hoe do I get my Uniden DECT 6.0 Cordless Telephone Expansion Handset with Caller ID off silent mode?
What's the answer???????????
SOURCE: Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
