TR 019 steam shower leaking water from top shower, shower head , body jet, foot massage when in the off position, looks like the control value has gone any ideas wher i can get a new one from?
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
SOURCE: Need assembly diagram for original Waterpik Shower
You just need to figure out which one you have and the manual should be on this site. If its not then give them a call.
http://www.waterpik.com/customer-service/instruction-manuals.html
SOURCE: Water runs out out both places for spout and shower head in tub!!
One of two issues. Either the shower valve was installed upside down or there is a twin ell ( Old School Diverter) Partially plugged. Odds are the valve is upside down.
Good Luck, Phil
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
