Samsung SyncMaster 244T 24" LCD Monitor Logo
Anonymous Posted on Aug 12, 2012
Samsung Monitor Plaid Screen
Monitor started displaying a "plaid" screen on powerup and resume from sleep. Eventually goes away but all of the colors are off. Video of plaid screen http://youtu.be/UyaWxEq-_WU Took the monitor apart and none of the capacitors on the power board appear to be bad, no bulges or leaks. Checked connectors and all appears ok but problem remains. Any ideas on what could be wrong and a source for parts?
5 Related Answers
Anonymous
  • Posted on Apr 17, 2008
SOURCE: Green Plaid screen
had same problem with ours. at end of one year had green problem and service replaced color wheel. know 1 year after starting to have same problem again. I will not buy this brand anymore.
Anonymous
  • 317 Answers
  • Posted on Jun 04, 2008
SOURCE: Green plaid screen
sw to a standard mode
A
Anonymous
  • Posted on Aug 06, 2008
SOURCE: Black screen
the monitor is dead...give up and buy another non-samsung product
Anonymous
  • 8637 Answers
  • Posted on Jan 09, 2009
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Anonymous
  • Posted on Mar 12, 2009
SOURCE: Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
I have a un75es9000f and the picture looks plaid I had some movers move it and after we hung it and turned it on it looks plaid and has a bubble on the bottom of screen any ideas of the problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Dynex 37 hiss and plaid screen
There are some components that have gone bad in the board. It could also be due to moisture inside. Please do not continue to use it and refer it to a qualified service technician.
Screen has no image except it looks like madras
Try to plug in this monitor to another pc. If it still does not show an image you may have to replace the monitor.
My lcd screen is plaid
Hi nailah4200, if your LCD screen is plaid , please call the lenovo support hotline 1-877-4-536686. They will check the manufacturer's warranty and if it is active, they will send that pc for depot.
Hope this helps...
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
Nothing but plaid on my laptop
This may be a screen problem. In order to narrow it down, plug in an external monitor. If the monitor works correctly, then it's a problem with your screen. Somethings that you can try are: With the external monitor, go in and unistall the monitor drivers, disconnect the external, and restart the laptop. Check the connections no the screen. If it's not the driver or connections, then it will be the screen and will need replacing.
Green Plaid Screen
I think what you are describing is a form of line paring which is caused by a defective IC in the video circuit those inputs are feeding. Post a email link ad I will send a pic of a screen that has this problem and you can let me know if thats what your experiencing.
2answers
Green Plaid screen
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
