Even with volume at 100 it is very low sound, but there is some sound
SOURCE: sound suddenly went out on Zenith TV Picture and
All of these Zenith's are modular in design. I'm sure you have a problem with the sound module. A replacement should be relatively easy to find at a local Zenith Dealership at a nominal fee. If you are handy, you can change it yourself or if not, bring it in for repair. The set is definately worth repair.
SOURCE: TV powers on with sound and no picture. =/
before you go any further, did you try to press the brightness control up? because sometimes the remote got stock, it might cause to decrease the brightness, use the control button on the front panel of the TV instead of remote to increase the brightness, if no progress try to shake the Tv if you can, if its a loss connection, you can see the screen flickering and if its the case try to unplug and plug in the wiring connections or call the nearest tech in your place. for more info about tv troubleshooting tips visit
www.my.electronicshelponline.com
The volume isn't 'stuck' at any level and I use the remote that came with the set. The problem is that I can vary the volume but it is at a much lower level than previously. Hencen even with it on 100% it's barely audible.
