When I restore data from my Iomega external HDD onto a replacement internal HDD on my PC, the PC fails to restart when prompted, giving a hardware conflict issue message. I used EMC Retrospect Express HD backup software as advised in the literature which came with my Iomega HDD.
SOURCE: Iomega Prestige 1TB External Hard Drive (34275) adapter
Hi LeoChen,
Most of the Iomega drive adapters do but not all. There's no information on Iomega's site regarding the voltage but if you look carefully at the fine print on the adapter, it should have a Input Voltage Range listing, normally 100-240, if this is the case then as long as you have a cord that fits from the wall to the adapter the adapter will adjust itself to voltage within this range. If you have one of the few that staes only 90-120V for range then the answer is no, but Targus sells a universal adapter for laptops that comes with an appropriate tip for your drive that does support 90-240V.
Hope this helps FixYa,
Chris
SOURCE: Moving my Iomega® HDD 80GB USB 2.0 External Desktop HD
You have to create a admin. user account on your computer. You do this from user accounts.
SOURCE: Is it possible to boot from an Iomega eGo
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
SOURCE: Hi,I have a Iomega Prestige
If a hard-drive becomes suddenly unresponsive, it is almost always a terminal failure. Sadly, there is no way for anyone except a very specialized laboratory to recover a damaged hard drive, a very expensive process. Fortunately, you have backed up your data, so you are only out the cost of the drive itself.
SOURCE: Hi there. I have
you could run the chkdsk utility click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive hope this helps
http://office.manualsonline.com/manuals/mfg/emc/emc_computer_drive_product_list.html
emc computer drive manuals
hope this helps
hope this helps
