2001 Chevrolet Tahoe Logo
Posted on Dec 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 tahoe will not shift from second gear
Can not get tahoe out of second gear i was just driving and i stopped at a stop sign and when i pulled off it would not shift from second gear someone please help.
  • peanut175 Dec 18, 2008
    ok i'll check the fuses again i visually checked them but they looked good. i'll put an ohm meter to them tomorrow thanks for your quick response i appreciate it.
  • peanut175 Dec 20, 2008
    turned out to be 3rd and 4th gear were shreded and required some major work
Anonymous
Level 2:
Sergeant:
  • Expert 233 Answers
  • Posted on Dec 18, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
233
Questions
6
Helped
104298
Points
555
This is known as "limp mode"
there should be a fuse in the dashboard fuse panel, or possibly the one under the hood.. one will be labeled trans or tcm - something of the like...test ALL fuses in the fuse boxes for good measure, and change the fuses if you find any blown.
ALSO....
Did you recently have a remote start system installed? If so, they need to hook up the smaller white wire in the ignition harness to turn on with the ignition power from the remote start unit. If the ignition wire and the white wire (transmission control) are not powered at the same time, the trans will go into limp mode.
My 02 Tahoe will shift in to Gear but won't move. Just sits there like ur holding down the brakes. I jacked up the rear of the vehicle and put it in neutral and i can't turn the rear tires at all.
I put my truck into drive or reverse n it will not move at all ...
www.cargurus.com > Questions > GMC > Sierra 1500
CarGurusJan 27, 2014 - Alright well normally I can feel my truck shift into drive or reavers but it's not but .... running while won't move,I mean it moves but won't change gear,fluids good ... I have a 2002 Mercury Stabler Car starts up fine but will not move ... I hear a pop and my tahoe stops pulling and no reverse either it just revs up.
Chevy Tahoe Transmission Problems - Car Forums at Edmunds.com
forums.edmunds.com > Chevrolet > Chevrolet Tahoe
Dec 16, 2009 - 30 posts - ‎22 authors
Vehicle won't drive in 2hi in drive or 3rd will move with rattling noise in 2nd or 1st. ...maintain 60mph and when I crested the hill the truck no longer would shift into 4th gear.... Can feel transmission engage in all but Reverse. GMC Yukon, Yukon XL Transmission Problems
Sep 26, 2010
Chevrolet Suburban and Tahoe No Start problems
Apr 27, 2009
More results from forums.edmunds.com
30 Common 4L60E Transmission Problems & Repair ...
I have a 2005 tahoe 2wd it has 96000 mile on it i started it up yesturday and put it in drive it act like it didnt wont to go like it was in second instead of 1st i wnt down the road and it didnt wont to...
Has the transmission fluid and filter been changed in it in the last 50,000 miles.Sounds like you have some shift solenoids sticking.Change fluid and filter
Shifting Problems
when has the last time you had a trans serv. done on it? if you take it to a shop the will tell you that you need a rebuild. thrid gear and over drive are about burned up.
4helpful
2001 Yukon XL SLT 4 speed Auto Transmission shift problem!
Sam,
I would start with a transmission fliud and filter service.
I would then have the trasnmission checked out by a transmission shop. The transmission most of the time has the direct drum band is starting to go. The shops can rebuild it no problem, This is a very common failure wiith the trasnmission.
Good Luck
2004 silhouette jumps in 1st gear shifting to second
Have the diagnosis performed by certified transmission shop. Possibly bad solenoid in transmission.
Car won't go into gear properly
it could be a few things bent shifting fork or first gear is out reverse runs off an idler that is conected to first gear.
Nissan 1999 Altima won't go into gear properly
howdy,you need a clutch..thats for sure,101%
MY TAHOE GRINDS IN FIRST GEAR AND STOPS GRINDING IN SECOND
possibly the case hardening has gone on the gear teeth on first gear
Mecury Mystique-Is there a safe mode?
fail safe mode should give you third and reverse
fault in the TCU or a soleniod failure
Wont shift into low when stopping
well the taking off in second could be a sensor or vacume line...but when you step down on the gas real hard it is suppose to shitf to low that would be your kick down vacume line..
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
