1991 Chrysler LeBaron Logo
Posted on Dec 18, 2008
1991 Labaron turn signal switch intermittently works
There are times that my turn signal switch works fine, but, especially in the summer heat, it seems to not work. When it is really hot, I can hit the top of the dash really hard a couple times, or even jiggle the switch when the wheel is turning to one side and get it to work again. Very aggravating. Any ideas???
  • darlyn1123 Apr 29, 2009
    1991 Labaron turn signal switch intermittently works"and i can`t find where the relay switch goes?
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Dec 18, 2008
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
12116
Points
83
Replace the flasher unit  $5 maybe
1helpful
3answers
What part needs fixed when my turn signal blinker blinnks very fast and sometimes not at all.If I put pressure on the turn arm it will stop sometimes or clicking my high beams on or off sets it right
Flashing too fast means that at least one exterior bulb isn't working. IF its an intermittent problem, once bulb could not be making connection at times. next time its flashing fast, stop the car and look to see which bulb isn't working. Replace that bulb, clean the socket at the same time
Why do my emergency flashers work, but turn signals are intermittent on 2004 ford expedition,what could be the cause of this ?
Cause could be from a worn out multi-function switch (blinker switch)
Filaments heat and expand and decrease in size as current runs to them, basically making and breaking a circuit several times, creating an intermittent switch that supplies current to the lights. These can go out, and will need to be replaced.
Left turn signal works intermittently.
Hello. You may have a faulty turn signal switch or an expensive relay module. A turn signal switch is way cheaper than a relay module.
1991 honda civic turn signal problem
I can't recall as its been a while since I've worked on the older Civics, but there may be 2 bulbs in the cluster. They are not that hard to pop out and have a look.
I have a 1991 mazda 323 and the right front and rear blinker does not work however the leaft blinker does
When you turn on the right blinker does the indicator light come on? It could be a faulty turn signal switch. The turn signals are routed through the hazzard switch, sometimes you can switch on and off the hazzard switch several times and the turn signals could start working again...Hey it's worth a try..
Looking for timing marks for a 1991 Chrysler Labaron 2.5 engine
the timing marks are in the top of the bell housing, there is a window that you look into for the timing mark, it is a straight mark that you use to time the motor.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
