Click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it or you might have to download them rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html it might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions
they will automatically search for and find the correct driver
hope this helps
SOURCE: samsung J700 / Kingston 4GB microSD memory card
Choose file -> select options -> transfer for memory card.
SOURCE: getting a memory card error in camera using
first of try your memory card by putting it in a card reader device and connect to the computer check wether it is reading or not and if it is working try to copy some image files to that and put back in the camera and check wether it is working if your camera have an in built formating option do that also so memeroy card will get detected by your camera some times if you put cards in other devices first they will ask to format the according to the devices onceits done then no problem if the problem is still there contact your camera supplier and memory card supplier sometimes in side cards there may be internal circutary breakage occurs
SOURCE: KINGSTON 4GB MEMORY SD CARD
card error in kingston sd card after taken picture. now in my card reader can't detact any picture...
SOURCE: hello sir,
Check the manuals of your Camera see if it supports up 4GB of Memory. Also note that some cameras can only take a particular kind of memory card confirm that your camera supports Kingston.
What kind of software are you asking about? The card doesn't need any software in order to be used.
