Http://kitchen.manualsonline.com/support/rival-1/rice-cooker/manual-5679326
http://kitchen.manualsonline.com/support/rival-1/rice-cooker/manual-5679326
see link above for manual download hope it is correct
SOURCE: Rival RCS200 problem
Try this:
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try to
assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
SOURCE: no instruction book for rival rice steamer cooker
http://www.rivalproducts.com/manuals/MANUALS/RCS200_43_68557881.PDF
SOURCE: No Direction came with my Rival rice cooker
http://www.rivalproducts.com/product.aspx?pid=999
here is the website that you can get the manual for your cooker... the rc101 is the same as the rc100. when that page comes up under the picture there will be manual. click on that and it will pull up in adobe reader.
SOURCE: need a manual for a rival 4350 rice cooker
Google "Rival 4350 Rice Cooker Manual". Then take your choice of downloads.
