Question about JVC DR-MX1 DVD Recorder/VCR
JVC MX-DR1 ejects tape - JVC DR-MX1 DVD Recorder/VCR
Posted by Regan Tingey on
1 Related Answer
Anonymous
  • 56 Answers
SOURCE: My JVC dv tape deck is broken and won't eject
open the top and try to force it out......or just try to open closeopen close by pressing the button....
Posted on Oct 07, 2009
Tape won't eject on my jvc gr-d60. help please.
Remove battery
Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
Nov 16, 2014 | JVC GR Video Cameras
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
I have an old JVC stereo model number MX-D301T. There are two issues with my stereo. First, the volume wheel has stopped working. It is stuck on the highest volume setting and does not change when the...
The volume is probably controlled by an IC that does all the work. It most likely has failed. It's unlikely that the wheel is the cause of the trouble, unless it has broken leaving the circuit fully open. But I think that unlikely.
If the unit has not been used for sometime then the second fault will probably due to the belts turning to goo!
Oct 01, 2017 | JVC MX-D301T Shelf System
JVC MX-C33 Tape Drive Problem
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
Dec 31, 2008 | JVC MX-J30 CD Shelf System
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
JVC GR D247EK #140M0089 - Camera stopped loading cassettes. Remains in eject position.
Remove the battery for 30 minutes and try again. When putting the tape on camera press only where indicated by an arrow. Good luck!
Nov 20, 2008 | JVC Cameras
Won't properly accept tapes/ tape won't fully insert
probably a bent cassette housing in the deck - time to seek out jvc authorized repair.
Jun 12, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Oct 17, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
JVC DR-MX1 DVD Recorder/VCR Logo
29 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
