Question about Intel Core I3 2130 / 3.4 Ghz Processor
Intel i3-2130 always working on 80 degrees
Posted by poppinsotiri on
White Zombie
    Top Expert:
  • 4,961 Answers
Try reseating the CPU heatsink/fan with some fresh thermal paste like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Posted on Aug 12, 2012
How do I change to farinheight temperature?
A Celsius degree is larger than a Fahrenheit degree by 80%. But, Celsius sets its zero point at the freezing point of water, which is 32 degrees Fahrenheit. So The conversion always includes adding 32 when going from Celsius to Fahrenheit and subtracting 32 when going the other direction. So the two formulas are as follows: Degrees F = Degrees C times 1.8 plus 32.
Degrees Celsius = (Degrees F minus 32) times 0.5556
Now, keeping it straight as to when to add or subtract 32 is also easy. Always do it while in degrees F. So, if you are going from degrees F to Celsius, subtract that 32 first because you are sill in F sized degrees. Conversely, when going from degrees C to F, wait until you've done the multiplication to convert your degrees to F, and then add the 32. Those 32 degrees in the differential are F degrees, not C degrees.
Finally, it may be easier to remember just the 1.8 or 180% instead of that 0.5556. That's ok. Just whip out your calculator and divide 1 by 1.8, which in math is called taking the reciprocal.
Sep 03, 2017 | Cars & Trucks
What is a 410A 3 1/2 ton air-conditioner low pressure at 80 degrees
??? 80 degrees ??? Anything below 100 psi is going to start freezing up. 410a refrigerant is approximately 32 degrees at 100psi. Typically a 410a low pressure switch will open at 50 psi.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 08, 2017 | Heating & Cooling
What is the acceptable temperature of a merc 230e?
A W123 230e? I had two, one always sat at about 80 degrees and the other always sat at about 90 degrees.
Feb 07, 2017 | Mercedes-Benz Cars & Trucks
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
Jan 19, 2012 | 2002 Chevrolet Malibu
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
Head bolt toqure
Hope this helps, from autozone site. Curt
Application:
Cylinder head bolt torque sequence
Note :
Torque sequence:
front | 3 1 6 |
of | |
vehicle | 5 2 4 |
Step 1: Lightly oil cylinder bolt threads & washers
Step 2: Torque to 22 Ft/Lbs
Step 3: Torque to 51 Ft/Lbs
Step 4: Loosen all bolts 180 degrees
Step 5: Loosen all bolts 180 degrees
Step 6: Torque bolts 1 & 2 to 25 Ft/Lbs
Step 7: Torque bolts 3, 4, 5, 6 to 11 Ft/Lbs
Step 8: Turn all bolts an additional 80 to 90 degrees
Step 9: Turn all bolts an additional 80 to 90 degrees
*** CAUTION ***
engine uses Torque To Yield head bolts (TTY) that
permanently stretch during the initial installation.
New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper Torque.
Apr 24, 2009 | 1995 Subaru Legacy
I cant open youtube
Go to Start > Control Panel > Windows Firewall> Exceptions> Click on add port.
Call it port 80.
In port number type in 80.
Then click on OK.
Then close all the windows.
Basically on the computer that is running apache (Server), YouTube is unblocking the port called 80. On some systems mainly XP home we found that port 80 was always blocked. Even though localhost worked, computers connecting to it would get an connection error. Also, if you have a 3rd party firewall, you have to unblock YouTube. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 08, 2009 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
Intel Server S5000VSA gives 3 beeps and no BIOS display.
According to the following document (pages 14-19) published by Intel .. That memory module is not listed as tested/working with that board.
Feb 19, 2009 | Intel S5000VSA Motherboard
LX90 Dec pointing out by 4 degrees over run
Go onto www.cloudynights.com and post this in the LX member forum-- and or go on YAHOO groups and post this in the LX90 forum--
Are you absolutely sure that your TIME and DATE and DAYLIGHT SAVINGS (yes-no) are correct.
On my LX90 the first alignment star is always NOT in the eyepiece but everything is OK once I center both alignment stars.
Feb 02, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Admiral air conditioner
20 degree's is the difference you are looking for.
Jan 21, 2009 | Heating & Cooling
Intel Core I3 2130 / 3.4 Ghz Processor Logo
118 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
