Question about Danby DWC283BLS Wine Cooler
Wine cooler frost buildup - Danby DWC283BLS Wine Cooler
Posted by j_kevin_smit on
Danby Customer Service
    New Friend:
  • 27 Answers
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Posted on Aug 16, 2012
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
I have frost on back of unit.what to do?
Usually if you see frost or ice it is because the Freon level is low. There is a 5 year warranty on the compressor and sealed cooling system so if your within that period, I would call the manufacturer.
May 14, 2016 | U-Line 75WC Wine Cooler
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
Jan 11, 2015 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
I have a GE ZDB24A under counter wine cooler that continues to frost up regardless of the setting. I have a second cooler downstairs which stays clean - no frost. What do I need to do?
check the door seal, make sure that its not ripped or dirty. Its possible that moisture is entering the wine cooler thru the door gasket. Frost is normally the result of warm moisture mixing with cold air. The door gasket should be the problem. if you thoroughly examine and its fine, let me know and we'll go to the next step.
Feb 06, 2011 | GE ZDB24A Wine Cooler
Why is there water in the bottom of my wine cooler
cos you have condensation inside due to the fact that it is not frost free OR you have a seal leak.....OR the door is constantly open and closed (my beer fridge is like that.....)
Jun 25, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Interior icing of back wall of wine cooler, Sears (Kenmore) model 461.99609, stand alone wine cooler
as this is not self defrosting you have to do it yourself..........warm air causes frost buildup!
Jun 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not cooling and frosting up on the upper right side in back
Sounds like a leak in the refrigerant system. Need a certified technician for this repair.
Apr 22, 2010 | Marvel (6SBARBSG) Wine Cooler
Frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Sep 05, 2008 | Marvel (6SBARBSG) Wine Cooler
Danby DWC283BLS Wine Cooler Logo
863 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
