Question about Advent Computers & Internet
Cursor freezing the cursor will not respond to the cursor pad input, it works ok with a usb mouse but not with the cursor pad, also the left and right input on pad not working
    Sergeant:
  • 180 Answers
Hi
It could be trouble with Motherboard or the chip under the track pad.
Try to re-install the mouse driver. and try to check.
In case if you have any trouble then do contact us here in Fixya.
Thank you
Posted on Aug 11, 2012
5 Suggested Answers
Anonymous
  • 324 Answers
SOURCE: left click for mouse does not respond - right click very slow
Hey, pufpuf!
It's kind of hard to tell without actually looking at it,but
as skotkoir sez, replacing it with a good used on is probably the better way to go. Sounds like you have one of two problems. Either there is something (foreign objects, food, soft drink residue) that is binding up the buttons and/or making them sticky; or something has broken in the assembly. Not much that you can fix.
Posted on May 08, 2008
Anonymous
  • 7 Answers
SOURCE: mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Posted on Feb 11, 2008
MysteryFCM
Steven Burn
  • 187 Answers
SOURCE: drifting cursor
Drifting of the mouse pointer is a well known occurance with laptops and is not something you can "fix" (occasionally you will be lucky and the manufacturer will release a patch, but this is very rare)
Posted on May 26, 2008
Anonymous
SOURCE: Touchpad has no tap, left key not working.
I had this issue and resolved it by doing the following:
-Open the start menu by using the windows button
-Use the arrow keys to highlight run and press enter
-Type 'control panel' and press enter, find the mouse properties and enter
-From the buttons tab in mouse properties, go to double click speed and change to slow and confirm the changes
-At this point it probably still wont work, so do the above again but change the double click settings to fast and confirm.
-Restart your PC and this should resolve the matter. you can alter the double click speed again if you wish :)
Hope this helps,
tbo
Posted on Jul 18, 2009
Shereena_M
Shereena M Smillan
  • 601 Answers
SOURCE: cursor freezes on screen and will not work with
Reinstall the chipset drivers.
http://support.acer-euro.com/drivers/downloads.html
Thanks
Posted on Oct 25, 2009
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Sony vaio AR51E mouse cursor doers not move as touch pad not respoNding, EXTERNAL usb mouse works fine any ideas??
Go to Control Panel
SEE mouse icon... OPEN this
see if the touch pad is disabled
Try to go to the site Sony VAIO model specofic download latest driver for the touch pad
there are specific setting to enable the pad somehate it some love it but you can sort it out by looking at Control Panel /device manager etc
if USB mouse is working at least you can navigate to find issue
Jun 11, 2010 | Sony VAIO VGN-AR720E/B Notebook
The mouse pad right and left clicks do not always respond
nope! the whole board matrix needs replacing. use a usb mouse
Aug 19, 2009 | Computers & Internet
Hope this helps,
tbo
Apr 06, 2009 | ASUS Eee PC 1000H Laptop
Touchpad on acer aspire 5100 series is locked
plug in a usb mouse, go to control panel>system>harware>device manager and click on the + sign next to pointing devices. Right click the touchpad and click on uninstall. Reboot the laptop and unplug the usb mouse. This should pick up the touchpad as new hardware and reinstall it. Hopefully this will resolve the problem.
Dec 29, 2008 | Acer Aspire 5100 Notebook
Mouse not responding.
I take it that you have a wireless mouse.
Myself I prefer the ones that plug into the console.
Jun 18, 2017 | Micro Innovations KB1045LSR Keyboard
Drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
May 26, 2008 | Toshiba Tecra M2 Notebook
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Computers & Internet Logo
222 people viewed this question
Top Advent Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Toby Lee
Toby Lee
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
