Question about Toshiba E-Studio 3511 Color Copier
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Posted on Sep 05, 2012
SOURCE: MY E STUDIO 4511 PRINTER BY TOSHIBA HAS AN ERROR
how to clear code F105 on my toshiba 4511
Posted on Sep 24, 2009
SOURCE: Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id ([email protected])
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Posted on Aug 14, 2010
SOURCE: MY TOSHIBA E STUDIO 4511 HAS AN ERROR F100 CODE.
format hard by power on+0+8 then 690 then start then2 then set then report the mashin or revision the logic may be there is a problem in it
Posted on Nov 06, 2009
Jul 28, 2017 | Toshiba Office Equipment & Supplies
Feb 13, 2014 | Toshiba E-Studio 3511 Color Copier
Jun 23, 2012 | Toshiba E-Studio 2040c Copier
May 23, 2012 | Toshiba Satellite C655DS5043 Notebook
Oct 07, 2010 | Toshiba e-Studio 350 Copier
Jun 30, 2010 | Toshiba Office Equipment & Supplies
Nov 17, 2009 | Toshiba e-STUDIO 4511 Printer
Sep 21, 2009 | Toshiba E-Studio 3511 Color Copier
628 people viewed this question
