Apple extreme airport
SOURCE: No wireless adapter found in XP on ThinkPad T41
Boot your laptop into windows. Go here to IBM Lenovo support and download the Cisco Wireless LAN Mini PCI adapter driver >>>>>>>
http://www-307.ibm.com/pc/support/site.wss/MIGR-42683.html
Once downloaded just execute the file as it is an .exe file, you will the wireless icon appear in the system tray (bottom right of the screen).
Regards.
SOURCE: Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
SOURCE: I am unable to activate
The wireless card is automatically activated when the correct wireless card driver is installed.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver.
When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive.
Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
