Panasonic SC-HT730 System Logo
Question about Panasonic SC-HT730 System
The dvd is not playing
There is power to the unit, you can listen to the radio, tv etc., however when you switch over to DVD, the disk does not play...rather it plays for a couple of seconds and then stops. Any idea why this is the case?
2 Related Answers
Anonymous
  • 4 Answers
SOURCE: Unit says Init Please Wait
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
[email protected]
Posted on Apr 14, 2008
Anonymous
SOURCE: Panasonic SA-HT680 DVD Home Theater Sound System
when i turn my home theater system on it says f61 then it shuts off can u plz help me out here =[
Posted on Oct 19, 2009
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Technika tv/dvd the dvd is only in black and white and wont play the discs
you can try using a DVD cleaner disk on your unit, try several times to make cretin it is clean then try your DVD`s again, if the unit was stored in a damp area this may be a problem, DVD players can be finicky due to this, there may also be a manufacturing defect in the unit that made it fail prematurely.
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
DVD disk jammed in Salora TV+DVD, DVD mode unavailable
press source buttton ( at hhe remote)
then enter 2 5 8 0
then dvd set on.
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
2helpful
The dvd doesn't work when on play ,
Most likely cause, dirty lens on laser. Quick fix: buy and run Cleaning CD ( Radio Shack etc ). Don't use a DVD cleaning disk as these often will not start up when the lens is dirty.
How do you get the sound to play from headphones only and listen to radio while dvd is playing?
Just press FM button. Blue Light turn off, and you can listen radio without interference. Gustavo (Alpine Buenos Aires)
Sound to radio but no sound to cds or dvds
I dont know what car you've got but,You need to hook up the blue amp remote wire for the antenna, when you switch to radio the antenna signal turns your car amplifier on and you get audio and when you switch to cd/dvd it switches it off because your car is wired that way, its a common issue with Mercedes etc.
When dvd plays radio comes through as well.
This unit needs to go out for service. There is an issue inside the circuitry in the unit.
Gary
4helpful
6answers
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Top Panasonic Audio Players & Recorders Experts
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
