Question about Ranger TR-696F SSB CB Radio
Need owner manuel for a ranger ar3500 - Ranger TR-696F SSB CB Radio
Posted by chattym1939 on
kathykinzer
    New Friend:
    Problem Solver:
  • 11 Answers
I need a timing chain diagram for 97 ford ranger
Become an E BAY member.Notice and purchase one or two of the hundreds of Professional Mechanics Shop Manuels. There are real garage shop manuels for virtually every vehicle made for sale and fair prices. Search- "Shop Manuels", Professional Mechanics Guides". If you just want a very basic book they have paperback Chilton's, Hayes and others. Personally I'd get a Pro book.
May 13, 2012 | 1997 Ford Ranger SuperCab
I have on and off speed for heater fan. Was told there is a fuse blown. I have no owners manuel ,and was looking for help on what fuse it might be.
if it turns on at all its not a fuse... if it only has off and hi then its most likely the heater blower resistor
Jan 20, 2011 | 2006 Ford Ranger
Need to know what fuses go where on a 2002 ford ranger edge pickup.Don,t have a owner manuel
Check in THIS LINK to looking the right Owners Manual that you need: Ford/owners_manuals
Hope this helps (remember to rate and comment this).
Nov 22, 2010 | Ford Ranger Cars & Trucks
I have an 05 ford ranger edge.The overdrive off light does not come on when I push the button on the shifter. Fuse 27 ok, anyone have any idea's?
check your owners manuel for a fuse .. if there is no fuse for o/d then the overdrive soleniod in no working ... the solenoid is located inside the transmission pan attached to the valve body -- first check to see if the connections on the transmission are good.. sometimes a wire will come dislodged from the group of wires in the plug
Dec 05, 2009 | 2005 Ford Ranger
Fuel pump I need the owners manuel broken down in the middle of no where Jackie
if you have misplace your owner manual give this website a try to see if you can download one its www.edmunds.com wish you the best of luck Michigan Man.also give these websites a try www.autozone.com and www.alldatadiy.com i am only hoping the best for you Michigan Man.
Nov 27, 2009 | 2006 Ford Ranger
89 ford ranger 2.3L distribtorless EFI...have three relays located directly under the high current fuse box under the hood(passenger side fenderwell)no description on there function,the plugs are color...
could be the crankshaft position sensor or cam position sensor failure or immobilizer problem
the wiring to those units is susceptible to failure over long time use
Jul 01, 2017 | 1987 Ford Ranger
I need the fuse box diagram for a '97 Ford Ranger
By the the way there john-boy from about this year up to 2005 have the same problem. The parts stores discount or otherwise don't have a manual that describes the locations either. The fusebox is also in the door jam and not under the dash as you explained. There are also half as many over again under the hood inside the power-box. On top of that there are fusible links in various locations. The inside covers of the panel are numbered along with the fuses and provide no real information on the function of the fuse or the relays either for that matter. A replacement Owners Manual is about as expensive and far more helpful in this situation. You will probably come out a lot better in the end joining a DIY Vehicle Maintenance site online. The book you see only shows you the workings for one car. The sites allow unlimited access to all makes and models for about $20 a year.
Jan 07, 2009 | 1997 Ford Ranger SuperCab
Ranger TR-696F SSB CB Radio Logo
60 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
