Reset mi partener p900 y me pide la tarjeta de memoria con archivo de imagenes y no la tengo como puedo bajarla de internet
Necesito saber como puedo bajar de internet el programa para que trabaja mi traductor ectaco partner p900 Language teacher and electronic dictionary, cuando tocaba un icono solo salia un cuadro con imagen y no cargaba entonces lo reset y ahora me pide la tarjeta que no tengo en mi poder. gracias por su atencion. soy de managua nicaragua
Posted by srosalesbck on
Brian Sullivan
  • Computers & ... Master
  • 27,725 Answers
Google translate
p900 reset my partener and I asked the memory card with images and file I have as I can not download it from internet
I need to know how I can download from the Internet the program to work my p900 translator ECTACO electronic dictionary and language teacher, when he played an icon just went out a table loaded image and then reset it and now I ask the card that I have in my order.
Thanks for your attention. I am from Managua Nicaragua
i am not sure what you need or are after whether its langauge pack or the drivers to run it
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: language packs or motherboard name audio driver you might have to try a few times to get it right
hope this helps
Posted on Aug 11, 2012
4 Related Answers
Anonymous
  • 327 Answers
SOURCE: Hola Mi pregunta es mas que nada por compatibilidad de Memorias y placas geforce.
welcome to fixya
could you plz tell me the problem in english
thank you
Posted on Jul 31, 2008
Anonymous
SOURCE: porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
ai tienes alguna forma de ayudarme via on line te le indico mi email: cyberchica_otra_vez arroba otmail punto com soy de Venezuela muchas gracias por su ayuda.
Posted on Oct 02, 2008
Anonymous
  • 13 Answers
SOURCE: MOTHER SY6BB 1.0
try www.soyousa.com or www.soyo.com
Posted on Oct 08, 2008
Anonymous
  • 256 Answers
SOURCE: QUE TIPO DE MEMORIA NECESITA PARA TRABAJAR OK
Necesito nombre del fabricador, modelo y mas informacion de los sintomas en detalle... Entonces lo damos sugerencia... Gracias que se ha considerado de neustro servicio... Contactenos con su informacion. Es la manera de como nos clasifican a nuestra habilidad...
Mi nombre es Constantino (arzconst)
Posted on Jun 01, 2009
Necesito bajar mis fotos de mi camara m340 a mi pc
Usted deber?a haber tenido el software incluido con la c?mara cuando lo compr?. Encienda la c?mara. Conecte el cable USB (modelo U-8) de la c?mara a la PC.Use el programa Easyshare para localizar sus archivos de im?genes y subirlas a su PC. Si esto es lo que no funciona, tambi?n puede utilizar un lector de tarjetas. Si uno no se construye en su PC, usted puede comprar uno bastante econ?micamente. Inserte la tarjeta en el lector de tarjetas y se mostrar? como una unidad extra?ble en "Mi PC". Crear una carpeta en su PC, ?bralo y seleccione los archivos de la tarjeta (unidad extra?ble) y copiarlos. Pegarlos en la nueva carpeta. Estoy usando un traductor en l?nea para esta respuesta, as? que espero que pueda entender lo que escrib?.
Hola Tengo un gateway NV53A y necesito cambiarle los chips de memoria necesito saber como abrir la maquina correctamente.
Saca la bateria primero
tRevisa en la parte inferior hay una tapa con dos tornillo y tiene un s?mbolo como el de la imagen.
Haz tierra tocando alguna pieza metalica
saca los tornillos y accede a la memoria
si la informaci?n te fue ?til te invito a calificar o comentar
Tengo una cannon power shot sd600 digital elph, en ella tengo 15 fotos y dos videos de 2 minutos cada uno la memoria es de 500 mb, pero el display dice memoria llena y no me deja sacar fotos ni capturar...
¡Hola!
Bienvenido a Fixya. Posible que sus videos y fotos se guardan en su memoria interna no en la tarjeta SD / tarjeta de memoria. S?lo tienes que seleccionar la tarjeta de memoria de dolor o guarda sus im?genes.
Gracias por usar ou Fixya,
seancarlisle
13helpful
10answers
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
2helpful
2answers
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
3helpful
Como puedo conectar mi Consola Peavey de 32 Fx en mi mac OS X 10 y tengo instalado Pro Tools M-powered y pro tool HD necesito que me reconozca los 32 canales para poder grabar en multipista.
Necesitas los drivers que deber?an venirte en un cd con la consola. Si no instalas eso, la PC no reconoce los AD converters que usa cada canal , que ser?a como agregar la misma cantidad de tarjetas de sonido nuevas, y es imposible que puedas grabar.
Si no tenes el CD, deber?as ingresar en la pagina del fabricante para descargarlos.
156helpful
8answers
No puedo entrar a mi cuenta de facebook
No puedo ingresar a mi cuenta en facebook me pide que confirme que soy una humano. Ayuda
Perdi el disco de drivers de la tarjeta Abit SG-72
Bajalos del website de ellos, problema resuelto.
Computers & Internet Logo
Ekse
