Question about Fisher and Paykel Washing Machines
SOURCE: Fisher & Paykel GW712 cold water dont work???
Just click below;
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
DON'T FORGET TO RATE;
Posted on Aug 26, 2008
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Posted on Mar 25, 2009
SOURCE: GW712 Fisher & Paykel Washer.
THE INLET VALVE FILTER COULD BE BLOCKED TURN WATER OFF UNDO PIPE AND CHECK IF NOT COULD BE A PROBLEM WITH VALVE ! IS YOUR WATER PRESSURE OK
Posted on Jan 12, 2010
SOURCE: My Fisher & Paykel Ecosmart Washing machine
Darn, well it is either the actual Solenoid, & Valve, or the Controller. I would check, both
www.casa.co.nz/.../SmartDrive-Parts-MW511,MWC11,GW511,512,611-25p.pdf
appliancejunk.com/forums/index.php?action=dlattach;topic=5943.0;...
Posted on Apr 21, 2010
Testimonial: "Thank you for the quick answer. I'll check both in the morning."
SOURCE: My fisher and paykel smartdrive 058 which has a
i am pretty sure its the main board, the easiest way to solve the problem is replace a the main board with a secondhand board, as well as obtaining a bag of spare parts, out a good working machine with faulty seals. You may have faulty seals if the machine is dormant for 3 years. I advise people never use washing powder in their washing machines, just use liquid detergent like Cold Power. the washing powder cakes up in the machine and when harden can be very abrasive and destroy the seals.
Posted on Dec 07, 2011
