Question about Samsung PCL541R 54" Rear Projection Television
What would the correct red green and blue settings for a 54 inch samsung rear projection tv
I took the speaker grill off and messed with the color settings now i think i boogered up the screen even worse lol. can anybody tell me how to fix this to a perfect picture? i mean can i turn the color on all tubes to 0 then set the dial to a certain position? does anybody know how many turns to position the dial that way for each color?
Posted by ryan fletcher on
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
Posted on Jul 07, 2007
Willie Howell
  • 1030 Answers
SOURCE: mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Posted on Jan 08, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: convergence out and turns itself off
You will need to replace the two Convergence ICs STK392-040 they are located on large heatsinks on the large board on the right side of your TV. You can order replacement ICs at the following link, and They will also include free instalation instructions plus provide free tech support if needed. here is the link
http://servicemanuals.vstore.ca/
Posted on Apr 22, 2008
Anonymous
SOURCE: samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Posted on Jul 29, 2008
ABRsvcs
  • 4234 Answers
This is a convergence problem that should be relatively easy to resolve, I am assuming that the set is new to you rather than new. If new, it should be under warranty and if opened would void the warranty. If new to you and you can solder, you should be able to fix this. First, realize that there are potentially dangerous high voltages present inside the set even when unplugged. Locate the convergence ICs (large black ICs attached to a heatsink and marked STKxxx) and resolder the pins. That may resolve the problem. If not, then replace the ICs. Check the area for small valued resistors that may be defective as well.
Keep us posted.
Dan
Posted on Feb 04, 2009
Tv gets light blueand stays that way...comes back to perfect color the back to blue X-RAy looking it is a samsung pcl545r
Behind the screen, there are three color tubes: Red Green and Blue.
Unfortunately, rear projection screens often have these problems and the tubes do go out after extended use.
Take the television to a TV Repair shop to have this fixed. But in the long run, this may end up costing you a lot more than if you would purchase a new TV. The light tubes are fairly expensive.
Jun 03, 2011 | Samsung PCL545R 54" Rear Projection...
I have a 52 inch RCA projection tv. Where are the color adjustment screws on the back of the tv that everyone keeps telling me about?
This is Chassis PTK195-There are screen/focus adjustment knobs (red green and blue) at the front of the set - behind the speaker grill and front access panel.
Oct 11, 2009 | RCA P52926 52" Rear Projection Television
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
3d picture
"Red means your set is heading towards being dead" is the general rule I've always followed. Red means there is some serious internal issues. There is one thing that might mean its not serious. If you have component hooked up, check the cables to make sure its hooked up properly with the correct colors on the correct color inputs. that can make a huge difference. If you have them incorrectly hooked up it can turn the image all red on your screen. Otherwise, it appears your set is headed towards needing some service. This is not something you can just fix on your own. Is your product still under the manufacturer's warranty or an ext. warranty? Good luck. keep us posted!
Sep 13, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
48 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
