I need a code for a GE unverisal remote
SOURCE: need tv code number for 32"LCD Dynex Television for my universal
Ran a search and someone said Funai made it's codes are 0818, 0179, 0171
Someone else said it's made by Orion codes are 0236, 0179, 0463
You can try these codes hope they can help you.
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: need code for ge universal remote for dynex 26
Try these codes for dynex televisions. Dynex Television 1023, 1107, 1122, 1273, 1382, 1383, 1384 If these codes do not work you can call the Dynex customer support at this telephone number 1-800-305-2204. Give them the model number of you television and ask them how to get the code. I hope this information helps you with your problem.
SOURCE: I have comcast digital cable
Here is the webpage for the Dynex remote codes. I hope this helps you solve your problem. (www.dynexproducts.com/universalcontrolcodes.aspx) Copy the web address and paste into the address bar in you browser. That will take you to the page that has all the remote codes for Dynex televisions. You can use the webs site for customer support also with the customer support e-mail. They will be able to help you find the right code if you cannot find it on the code page. The Dynex customer support telephone number is 1-800-305-2204. you can contact them between the hours of 7am and 12am CST.
SOURCE: my dynex remote control for 32 inch flat screen
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
