My cobra 148gtl needs pll chip replaced can i use one out of a 959dx
SOURCE: cobra 148gtl
tomcat 1 back ...i have found the fault no modulation on am/usb/lsb.tr -23 a bc458 transister .replaced this transister and wow modulation on all 3 modes thanks zeppfrog for telling me where to look .
SOURCE: Cobra 148GTL Missing TX Modulation
The problem is most likely the audio ic . open the radio and see if the diode 44 is blown or see if you see anything that looks like it got hot around the plug area. if not contact me and i will buy it. is it an old or new 148 gtl.Read more
SOURCE: Installing an Astatic Echo Board in a Cobra 148
There should have been instructions that came with your reverb board. You are going to need to drill another hole in the case of the radio, or find a control where you can install a dual control knob onto.
Your reverb board is likely going to need 8v, so you will need to locate that off the logic board, likely from the frequency synthesizer. The the audio lines from the mic, or the output of mic amp, are going to be redirected to the reverb, and the output of the reverb feed back to where the wires were removed from.
If I recall correctly, the 148 is a bit of a bear to work with, not much room inside. You will likely have to get creative in placement of the reverb board itself. Make sure to wrap well so that it doesn't get tossed around and break something inside.
