Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
Pass key to playstation bluetooth headset crysis 2
4 Related Answers
Anonymous
SOURCE: need pass key for madcatz 8860 bluetooth headset
Yeah for every headset its 0000
Posted on Jan 18, 2010
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
SOURCE: PS3 Bluetooth® Headset Wireless Headset: i need a pass key for my bluetooth headset model #...
First try '0000' (four zeros). If it doesn't work, switch to '1234'. It it keeps failing, try '8888'.
Hope one of these codes might suit your case.
Cheers! Carlos
Posted on May 20, 2010
Anonymous
  • 185 Answers
SOURCE: lost my pass key for ps3 bluetooth headset
is not 0000?, most bluetooth headset use that code because there is no way to change it not like cell phones that you can enter whatever you want.
try that and if it works don't forget to rate me
thx
Posted on May 25, 2010
award462
Anthony Ward
  • 397 Answers
SOURCE: bluetooth headset mn8860
You can use it with any Bluetooth phone that supports HFP/HSP, which is most any Bluetooth supported phone.
Posted on Jun 02, 2010
Hi my name is Jonathan and I lost my manual for my TB-92Ex Bluetooth and I'm trying to connected to my playstation and I don't know the passkey can you tell me what the pass key is to my Bluetooth
Set the Playstation settings to scan for devices, then press the headset button (hold for 5 seconds.) The headset light should flash while it is discoverable, then it should appear on the playstation device list. You should not need a passkey.
If I have a ps3 bluetooth head set and forgot the passcode?
If you don't know the correct pass key, consult the instructions for your Bluetooth device.
1helpful
What does error code 80010009 for the crysis bluetooth 2 mean
Incorrect passkey for Bluetooth device. Description: Entered wrong passkey for the Bluetooth device when trying to pair it with the Playstation 3.
Source: http://us.playstation.com/support/answer/index.htm?a_id=939
4helpful
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
2helpful
What is the pass key for my mad catz bluetooth ear piece item number 8860 and how do i synce it with my playstation three
The pass key for the Bluetooth headset is 0000 (four zeros).
If you need further assistance please do not hesitate to get back to me.
Hope it helps.
2answers
1helpful
Lost code for bluetooth for playstation 3
Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
