Question about Sony Televison & Video
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
TV has been flashing odd colors on left side of screen for a couple of weeks; today screen is black with only a thin, blue horizontal line about three inches up from the bottom of the screen. Any ideas out there? It is about three years old, so no warranty.
Posted by Melody Lysgaard on
  • Melody Lysgaard Aug 11, 2012
    Any suggestions would be appreciated.
    Top Expert:
  • Sony Master
  • 76,584 Answers
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Posted on Aug 11, 2012
5 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a Flat screen
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Posted on Apr 02, 2010
Anonymous
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500 40" lcd hdtv
I risk getting a bad rating from you, but it sounds as though you have a bad LCD panel. I have seen sections of the panels fair, usually caused by a separation of the ribbons connecting to the panel itself or a bad TCON board (the board that addresses the pixels. It is part of the panel on Sony TV's). Your best bet is to contact Sony customer service at 800-222-SONY to see if they will work out some kind of accommodation on the repair, like possibly covering the parts or splitting the repair costs with you. I hope I have provided you with good information and you do not rate me poorly for your bad news.
Posted on Nov 10, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
Posted on Dec 13, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I have one thin vertical line on screen left side blue in colour
You may have failing T-CON board, http://www.shopjimmy.com/catalogsearch/result/?q=42lc2d
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 30, 2010
Anonymous
  • 1284 Answers
SOURCE: I have a sony bravia
If the balck line extends from top to bottom and is only a pixel in width then your LCD panel is at fault.
Posted on Sep 01, 2010
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
My sony bravia 32" is
hi ;
there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck.
if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line.
thanks.....
Sep 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
Jun 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
Feb 24, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
A thin blue line has appeared on my sony bravia tv screen
The screen is delamminated take it back and get a new one
Nov 02, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia lcd
Sounds like a possible T-con board failure. Which would need to be done by experienced tv repairman
Nov 20, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
