Zondervan NIV Study Bible Complete Library Full Version for PC Logo
A
Anonymous Posted on Aug 09, 2012
Can't run zondervan niv study bible on windows 7 64 bit
1 Related Answer
Anonymous
  • 82 Answers
  • Posted on Oct 09, 2007
SOURCE: Zondervan NIV for windows pda
install the new ver of pdf or AOV REDR
1helpful
3answers
Problems downloading my NIV Study Bible
you need to look for a new program that can read PDF files... like adobe pdf reader...
so what you need to do is uninstall your pdf reader, download a new version (even if its the same because the one you have now is corrupt and malfunctioning)
and then install it to enjoy what you need to do..
i hope that now you can understand the solution and fix your problem...
Bible download niv
Not sure if I understand your question. My favorite Bible app is Blue Letter Bible. This can be found on the app store. It has most all of the translations including NIV. I prefer King James, but to each his or her own. Best of luck!
Bible download niv
You can download the Bible from this WEB site.
http://www.biblegateway.com/blog/2013/01/niv-now-available-for-download-in-the-bible-gateway-app/
I CAN NOT INSTALL IT ON MY NEW COMPUTER
First of all, please don't write with caps. Second, this software is for Windows 98, which you are probably not using. Did you installed it and do you have a problem opening the program, or does the hole installation did not work? If you can't open the installed file, click with the right mouse button on the program and choose properties. In this menu, press compactibility, and select the first []-button, so it will look like this: [V]. Select Windows 98, then save these options by clicking OK. It should work.
Some letters in the display are malformed. If the text is scrolled, the problems move on the screen - its not pixels on the screen that are faulty. The fault appears to be in the data. I've tried reset but...
Simple. Hold the niv device in your right hand. Stand up. Walk to the nearest garbage can. Drop the niv into the garbage can. Take the garbage to the curb. Go to eBay and purchase a real Bible, the Franklin KJB-640, the actual Word of God, AKA, The King James Bible. Best electronic Bible ever made.
Problem Solved.
See? That really was simple, wasn't it?
RC
Is it possible to load Bible book (not audio) into my Ipod? How? I have in it loaded already an NIV audio Bible. I want the book to read for Bible study. Thank You.
Hello and thank you for using Fixya's services.
You need to make sure that the Ipod is compatible with the filetype in order to load and see correctly.
To do this, right click on one ofthe Bible files and choose properties. See if you can tell what file type it is. I believe that Ipods only support a handful of files types.
You can also check out this free software for adding video's to your Ipod, it will show you how to convert the files to a compatible version if need be.
http://www.splashdata.com/filemagic/
Hope this helps!
1helpful
Get started with quickverse white box
Go to quickverse.com download white box 2.02 upgrade.
Top Zondervan Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zondervan Computer and Internet Expert? Answer questions, earn points and help others
