Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher Clean light flashes after reset goes through cycle but motor does not run then clean light comes on again.
The dishwasher seems to go through the cycle to a point. It inputs water, heats it, dispenses the soap, and remains silent when it should be washing (the motor doesn't run?), drains and then just sits their until the Clean light starts flashing. Is the motor bad or maybe it doesn't get the signal to start?
Posted by bmorton739 on
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Posted on Mar 21, 2007
DENNIS MITCHELL
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
Anonymous
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
Anonymous
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
1helpful
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
1helpful
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 • Dishwashers
65helpful
2answers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
28helpful
3answers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
8helpful
4answers
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
