SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
SOURCE: pride mobility celebrity 3 wheel
This problem could occur due to various reasons.So lets find out what could be the cause.
1)Check lever is in correct place.Levers control the switch that controls the brake.if the brake is disabled this will stop the scooter from moving forward or backward.
2) Check the brush in the motor,If it is stuck release it and tighten the caps.
3)Thumb levers that control forward and reverse motions.See the the lever is not detective one and it is working properly.Take apart and check the wiring connections.
4)Check free Wheel lever is jammed which is located on the drive motor,and check the lever is not bent.
5)throttle lever is worn out sometimes you have to replace it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: turn key on pride celebrity scooter. everything
As a mobility tech you can log onto the Pride Service website and access the technical troubleshooting guides. There is a good one for the Celebrity X . If your company has a dealer account with Pride you can go on-line and request a log-in for tech/dealer access for illustrated parts breakdowns,parts ordering, service manuals and trouble-shooting guides etc. It may take 24 hours for the log-in approval but if you call in the AM they may be able to expedite your request. iPride and Pride service are very effective in providing all the information you will need. Hope this helps.
SOURCE: need a spare key for my pride mobility scooter
Any hardware or home center can cut this key for you ... Take it with you when you go.
Thanks for visiting today.
