Microsoft Internet Explorer 7 Logo
Jan Miller Posted on Aug 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Interet Explorer high contrast
How do i undo high contrast (black background) / large print ? The icon in the taskbar which i used to get this will not show this icon now. only the wireless and volume are showing
Brian Sullivan
Level 3:
  • Microsoft Master 27,725 Answers
  • Posted on Aug 10, 2012
Brian Sullivan
Microsoft Master
Level 3:
Answers
27725
Questions
Helped
5664406
Points
79191
Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
hope this helps
1helpful
Windows 10. How to force windows explorer background to be set by themes as it is in windows 7 ??
Hii,
You can contact to Microsoft Officials or Experts at 1800-102-1100.
& if you want to contact Technicians for Microsoft, you can contact on 1800-626-1046.
Thank You.
tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
2answers
How to Enlarge Thumbnails in Windows Explorer?
Open the libraries folder. Or you can open another folder, such as the pictures, downloads, computer, etc. It doesn't matter which folder you begin on; all the Windows Explorer folders have the same method of enlarging the thumbnails.
Locate the taskbar near the top of the screen. On the upper right side of this, you'll see three icons. The first one on the left side, when rolled over with your cursor, should read "Change your view."
Click on the "Change your view" icon. A small menu will pop up with a list of different ways the Windows Explorer can present itself.
Select "Extra Large Icons". The icons will become large enough for you to see easily.
Repeat for all other Windows Explorer libraries.
I pushed something got to somewhere changed screen color. Internet color black background ghostlike pictures hair and stuff white now I want it back the way can't find it can anyone tell me where to find...
Sounds like you turned on the High Contrast setting in the Ease of Access section.
You can try and use the default key shortcut to deactivate it left ALT + left SHIFT + PRINT SCREEN.
Or navigate to the Ease of Access section through the control panel. Open control panel > Ease of Access > Ease of Access Center > Set Up High Contrast > (try) Choose a High Contrast Theme
Let me know if that helps
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Black background web pages
Step 1:
Web Pages That Do Not Display All Colors
Web pages that do not display all the appropriate colors have either a browser-related issue, monitor display problem, Windows comparability glitch or incorrect web pages Internet and HTML settings. More than likely, a setting dealing with your contrast ratio in Windows is the culprit. Once this issue is resolved, your web pages will display properly and accurately like they were designed to from the start.
Click on "Start" and navigate to the right pane and click on the "Control Panel." Click on "Ease of Access." Click on "Ease of Access Center." Click on "Set Up High Contrast" (one white and black box overlapping each other.) Check or uncheck "Turn on or off High Contrast when left ALT + left SHIFT + PRINT SCREEN." Click on "Apply" and close the Ease of Access Center. Press "ALT + left SHIFT + PRINT SCREEN" to turn on high contrast. Open your browser and go to a website to determine if color is restored to normal.
http://en.kioskea.net/faq/60-white-background-s-problem-in-web-pages
I have an HP1110n....It acts like it is booting up, but I only see my screen background pic. No icons show up. The disk spins and is doing something, but it won't display ANY icons ! Help !
This happens when Explorer (the file manager - the program that makes all the files visible on the screen) doesn't starts at boot. Press Alt + Ctrl + Del to open Task Manager. Click File, click Run and type explorer. Click OK and the icons and the taskbar will appear. If it doesn't start or it's faulty in any way you will have to reinstall Windows.
Hi sir.i was burning a dvd,suddenly,my screen has become completely blank,with no icons and specially my taskbar.my screen in completely blank
your explorer.exe process crashed. this is the background process responsible for your interface. you can solve by restarting the computer, or by entering a run command and typing "explorer.exe"
15helpful
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
