Question about NorStar Meridian M7310 Phone
How can I program Norstar M7310 to announce pages
I would like for pages to be announce on the speaker of an individual M7310 phone.
Posted by Julie on
curlycord
    Scholar:
  • NorStar Expert
  • 277 Answers
To page - F60
To receive a page make sure the phone is in the correct page zone under Set Capabilities in system programming.
Posted on Aug 10, 2012
5 Related Answers
Chintu-KPV
Chintu-KPV
  • 202 Answers
SOURCE: Norstar m7310 phone
Go to 'Setup / Feature' -> look for the menu item with option as Tone OR pulse...this is where u have to change :)
Posted on Feb 09, 2008
Anonymous
SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
Posted on Jul 03, 2008
Anonymous
  • 108 Answers
SOURCE: rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
Posted on Aug 17, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Posted on Mar 19, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
Posted on Jun 03, 2009
How can I program an all call button on the NorStar Meridian M7310 Phone to intercom everyone in the office simultaneously?
I guess you want a page key programmed on your set. press feature *3, press a memory key, press feature 610. This key pages all sets when pressed.
Dec 07, 2016 | NorStar Meridian M7310 Phone
How to change a time on NT8B20AB NorStar M7310
You don't change the phone time, you need to change the system time for all phones on the system.
Norstar How to program phone how to program voice mail features for... b41664b0-f579-4647-a0ad-d844545b8148.jpg
Mar 10, 2014 | NorStar M7310 Phone
Disable paging on individual phone
Yes, set the paging group to none in programming.
Aug 21, 2012 | NorStar Meridian M7310 Phone
We have a Nortel Norstar M7310. Approximately ten years old. Upon answering the phone the caller is automatcially put on speaker phone. The call cannot be taken off of speaker phone. The phone also...
my recommendation is to put the same model phone at that station and see if it does the same thing. Its been almost ten years since I installed those systems, but I do remember that you can swap phones and locations as long as the phone model is the same. my guess is that the phone is broken somehow as those symptoms arent really a programming issue. The individual button programming stays with the location and not the phone, therefore you would have the exact same lines and programmed buttons if you could temporarily replace. hope this helps some
Sep 20, 2011 | NorStar Meridian M7310 Phone
Ringing multiple intercom numbers at once
That was a good solution to the problem. way to go.
Feb 10, 2010 | NorStar M7310 Phone
M7310 doesnt page when i press page button
So pick up the handset and press FEATURE 63. Does that work?
If it does, press Feature *0 and the button labeled PAGE. What does it say? If it doesn't say PAGE, dial FEATURE *3 the PAGE button and dial FEATURE 63.
Of course, it's possible that your whole phone system lost the programming. And, it's also possible that the all page code is 60x instead of 63. FEATURE 6 starts external paging though.
Carl
FEATURE 60 Page-General
FEATURE 61 Page-Sets
FEATURE 62 Page-External Speakers
FEATURE 63 Page-All
Dec 09, 2009 | NorStar M7310 Phone
How to page a specific exten through the speaker on the Norstar meridian m7310
Press your voice call key (or feature 66) and the extension number.
Sep 17, 2009 | NorStar Meridian M7310 Phone
Need to change phone directory
This is in the vmail programming thru f983, once in here you can change the spelling of the individuals names for the directory,
dan
Aug 12, 2009 | NorStar M7310 Corded Phone
Lower the volume or disable page/announcement?
For paging u can't change the volume. The only way is to reduce ur phone's speaker volume.
Thanks.
Jul 09, 2009 | NorStar T7316E Corded Phone
PROGRAMING PAGE FEATURE ON M7310
First try this. Press FEATURE 601. If that pages all speaker, then I remembered it correctly. If not, Try 6xx 602? 612? until the display says PAGE ALL. That's the feature code.
Now, pick a button. Press FEATURE *3 the button and dial FEATURE 6xx with xx being the code you used above.
Now when you press that button, it will page as you desire.
Carl
May 21, 2009 | NorStar M7310 Phone
NorStar Meridian M7310 Phone Logo
486 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
