Printer remains on but no initialise. also printer green led on when door is open.
SOURCE: All LED blinking
try to reset the printer:
- Machine off
- Front cover OPEN
- Switch on the machine while holding down the “GO” button
- Check that the TONER/DRUM/PAPER leds are lighted
- Release the “GO” button and check that all the leds are off
- Press the “GO” button 2 times
- Close the FRONTCOVER
In case of all the leds are flashing on/off, that means the printer hardware fails somewhere. To find out what section fails, you can press down the “go” button and a led will go on.
Toner >> FUSER FAIL
Drum >> LASER UNIT FAIL
Toner + Paper >> MAIN MOTOR FAIL
Paper >> MAIN CONTROLLER BOARD FAIL
If you cannot determine wich led goes on,it seems that the main board is broken.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: we r have epson c45 stylus printer.after initialise red and green
The Waste Ink Pads are deemed to be saturated and should be replaced.
You can overcome this problem temporarily bu using the SSC utility -
download from
http://www.ssclg.com/epsone.shtml
and
reset the Protection Counter. However, remember that eventually ink
will overflow from the waste ink area and make a dreadful mess, so you
must change the waste ink pads before this happens. This requires the
disassembly of the printer. A copy of the service manual is available
from a number of sellers - just Google "Epson C45 Service Manual.
SOURCE: hp laserjet printer 1007 windows 98 driver
goto www.hp.com click on "drivers & software" type model of printer and it will take you to the selection of what software you are using so you can download your driver.
SOURCE: I am wanting HP 1007 pritner driver to install
I am wanting HP 1007 printer driver to install
Hp 1007 laser printer on position but no initialise pls ply me
