Hello
When the service engine
soon light (Also called the check engine light or engine management
light) is turned on this is to alert you to the fact that Powertrain
Control Module (computer) has detected a failure somewhere in the
systems it controls you may not feel any difference in the way the
engine runs, this can be the transmission or the engine or emission
system, there are fault codes set in the modules memory for these
faults. What needs to happen now is to have the powertrain control
module scanned with a special tool called an OBD2 electronic engine
control scanner or a OBD2 code reader. Once the code(s) are read then
you must perform the diagnostics for each code and make the
appropriate repairs based on the findings of the diagnosis that was
performed, this is called doing "Pinpoint" testing.
SOURCE: Hi i have a BMW 1 series - faluty hydraulics
The trick with these sellers are that they would say the warranty does not cover wear and tear and they will say this is not under cover,this is a typical trick they use in the UK to catch poor victims.Look for a cheaper labour as this is just a joke to have it repaired at a garage for this cost.Hydrualics is to do with power steering etc and this is an important part for this vehicle to function properly.Get in touch and if you are local I can help you.
SOURCE: BMW 328 i 1997: Start up problems / Stuttering / Engine Light
change the pcv valve its under the intake manifold
SOURCE: BMW 3 Series light on dashboard comes on
If the triangle has an ! in the middle of it then it's to indicate that DSC or DTC is on for stability.
SOURCE: where is the oil filter located on the bmw 116i
right at the front in the middle below plastic housing. Has 1 large plastic cap on a metal lower casing, not metal bodied like old oil filters just has filter element. Also replace 'O' rings that should come with the new filter as the old will have squared off or become perished. I think you need a 27mm socket to undo the filer housing.
SOURCE: bmw 1 series wont start
my bm 1series came to a shudder a code came up p0012 got the actuator cam. from main dealer fixed still wont start
