Locate the bobbin access panel to the right of the presser foot. Place thumb tip in the oval hole and pull to the left, (It might also tip up, but I doubt it.) Reach in and lift and grasp the little lever on the bobbin case, pull it out. Remove bobbin from case. Select the thread you want to fill the bobbin with. Place it on the thread spindle. Pull thread trough the small round tension disc on top of the machine and back toward the short spindle on the right top of the machine. If your bobbins have holes.. thread a hole and place the botton on that short spindle. Slide the bobbin and spindle toward the metal "fence". Loosen the hand wheel by turning the center knob counter clock wise. Grasp the little thread on the bobbin and start winding a few revolutions with you holding the thread. Stop and clip that short thread close to the bobbin then continue winding until full.
When the bobbin is full. Return the hand wheel knob to it's original position. Slide the bobbin winder spindle away from the "fence" and remove the bobbin. Place the bobbin in the case with the bobbin facing you... the thread when pulled should rotate the bobbin itself clockwise (VERY Important!) Hold the lever open and replace the bobbin.
For your convenience I have located this PDF for your machine. (be patient, it takes a while to load)
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/38ca989591640b1a852575f30058c8ff/$FILE/Pfaff%20260%20.PDF
Posted on Aug 09, 2012
Nov 21, 2017 | Sewing Machines
Mar 10, 2017 | PfaFF Sewing Machines
Nov 03, 2016 | Sewing Machines
Feb 22, 2015 | Husqvarna Sewing Machines
Apr 04, 2014 | Husqvarna Freesia 415
Apr 09, 2012 | Singer 1507
Sep 26, 2009 | Husqvarna Viking 1
Jun 07, 2009 | Janome Memory Craft 5700
Dec 16, 2008 | Husqvarna Viking 1
Jun 14, 2008 | Sewing Machines
Jan 18, 2020 | PfaFF Sewing Machines
Oct 14, 2019 | PfaFF Sewing Machines
208 people viewed this question
