SVA-USA VR-3200W 32 in. LCD Television Need the code for remote control from dish
SOURCE: remote control codes
The only remote that works is the one 4 all. Call ONE 4 ALL for the right model number. They then can program the remote on the phone to operate the SVA tv. It worked for me until the set died this week. Guess why I am looking on this site.
SOURCE: original SVA42HDTV08lll-PDP remote control
I purchased my HD4208TIII-pdp remote at www.remotes.com. Works awesome...
SOURCE: SVA television. Have model # EV1703 Remote no
When you say the remote doesn't get the channels I have to assume the channel entry behavior changed. I am not to familiar with this brand but these are the basics for most tv's. If you have not removed the cable input to the tv or unhooked anything before the problem started here are a few thing you could try. Push the menu or setup button on the remote and under the channel or setup option on the tv make sure it is set to Cable and not Air or Antenna. Run the tv through the auto channel search to reprogram the cable channels. This process can take close to 1 hour on some tv's since it has to scan through the digital and analogue tuners. This will allow your tv to add the correct cable channels and remove the unwanted ones. You should be able to enter the channel number or move up and down with the channel buttons on your remote.
SOURCE: I have a SVA VR
The power supply may have failed due to bad DC filter caps which you can easily look at them for sign of elaking/bulging top first.
Post back what you see inside so we can guide you further.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
http://www.hifi-remote.com/ofa/codes-tv.shtml
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
http://www.logitech.com/en-in/440/3898?selectedcrid=440&selectedcid=3898&WT.z_sp=Product&osid=&bit=
http://www.usa.philips.com/c/remote-control/12532/cat/#/cp_tab1
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
