Question about StarTech.com StarView SV211K 2-port KVM Switch
Need pin number for Eurovox radio modelmcc-6630. Serial no on rear of radio shows model 92039986 serial no. 234019518-1
Posted by Warren Ross on
What is the radio code for peugeot radio cassette eurovox mod8970 serial number 322003454.0.
YOu will have to get in touch with the manufacturer.
Be ready to prove that you own the car, make sure you have the correct paperwork.
You may even have to pay a small fee, but sometimes you do not.
Good luck.
Jan 08, 2015 | 1995 Peugeot 306 Cabriolet
I need to find a pin code for my ford cd stereo serial number m14790931
please im despatly need code for my Ford ikon amb 1.6. the car radio serial no: 328829060935
part no: 8a39-18c939-dc
model no: 14790935
Nov 12, 2012 | 2008 Ford Ikon 1.3i
Hi I purchased a Citroen Berlingo 2005 second hand.Radio needs cod, I don't have. Radio is a eurovox 3385 model no.MOD3385CIT1 serial no. 46000825.4. can anyone help.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Citroen service centre and get them to enter this code for you.
Sep 23, 2012 | Car Audio & Video
Need code eurovox 7479b serial n 294000871.5.
The cheapest and best I can suggest are these, Cheaper than Dealer by a long way and guaranteed. You will need make, model and serial number.
Hope it helps.
http://uk.ebid.net/for-sale/car-radio-unlock-codes-39361901.htm
Mar 20, 2011 | BMW Car Audio & Video
I have replaced the car radio antenna on 1993 Discovery. Works fine on am very pore reception on fm. The car radio, factory fitted, is Eurovox Model 92039986. Is there an adjustment to tune the radio to...
Check your connections on the antenna again. Am usually gets decent reception. sounds like your antenna connection isnt fully connected either at the stereo connection or at the actual antenna connection.
Mar 29, 2010 | Car Audio & Video
I need pin code for my ford focus radio The Serial number wf03xxgcd35p59424 if some1 could decode this id be so grateful please help me , or even guide me to a place where i can decode it
You can call your ford dealer with the serial number and VIN and they can give you the PIN, you may have to show proof of ownership.
Nov 23, 2009 | 2004 Ford Focus
I have a 2003 suburban.my radio didnt work.i bought anither same model radio from ebay. when i put it on it says locked. need help. how to unlock this radio. thanks
If it is a Eurovox brand you need the pin code. If you dont have the pin code you need the serial number of the unit and you can get the code from a company called Go Technologies via the www.eurovox.com.au webisite. This costs a small fee and the application form can be downloaded from the website.
If it is a Eurovox radio you can enter 1111 if the code is a 4 number pin of 111111 if the code is the 6 number pin. This will put the unit into test operation for about 3 minutes to at least see if the unit works. While in this mode the screen will blink continually.
Sep 11, 2009 | OEM Systems Car Audio & Video
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
109 people viewed this question
Top StarTech.com Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
