Question about Samson Xm910 8Channel Powered Mixer 900watts
Power mixer to a power amp.
Can i connect a 10channel samson 900watt power mixer amp to a gli pro xa5500 3500watt amp and use it with various speakers.
Posted by Dejesus on
Darren Stagg
    New Friend:
  • 61 Answers
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Posted on Aug 10, 2012
3 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: what is the likely cause of the phantom power of a
The phantom power is used for condenser mics. MAKE SURE you do not plug in other mics or devices that do NOT have balanced, isolated outputs as they will short out the phantom power to others.
You should find between 15 and 48 volts between BOTH pins 2 and 3 of each mic connector when measured to pin 1 of the connector. There is about 6K ohms impedance from the phantom supply to pins 2 and 3.
IF you have an accident and connected high voltage to pin 2 or 3 it COULD back up and blow the bypass cap for the 48 volts.
Please note: ALWAYS power ANY interconnected equipment from teh SAME receptacle to avoid damage due to ground bounce in the event of a fault in a piece of equipment.
Posted on Oct 23, 2010
Fred Yearian
  • 5603 Answers
SOURCE: The audio kept cutting in and out while using the
The unit is SUBJECT to radio interference from other systems in the area such as high power taxicab radios for example and other services. 30 seconds might be about the time for a radio transmission. The system, while being interfered with, likely will NOT generate audible sounds and due to the squelch algorithm may MUTE the system.
Sorry, but you are a SECONDARY user per FCC definition and they are licensed and you are sharing bandwidth. You cannot interfere with them, but they can interfere with you. You should probablly get a UHF system that has less chance of interference. While recording, frankly I would be wired, not wireless. I am both an electrical engineer nd a HAM so I am aware of these problems.
Posted on Mar 28, 2011
Testimonial: "Very quick and thought out response! Great. "
heminway kevin
SOURCE: hey, i bought a new
I have a 412 speaker that works good at low volume with simlple set up when key boards turn up on mixing board the red peak light comes on and speaker shuts down i think its a protective shut of for overload but very easily triggered have to work with material too find a solution can any one confirm this shut off phenomena
Posted on Jan 06, 2012
Hum from Samson XM610 Powered mixer
hi, my samson xm610 have a problem even i tern off the voluem of each chanel still have a sounds be fore is not just like that.. can you help me
Aug 27, 2012 | Samson Xm610 Powered Mixer
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
Getting distorted sound when connecting from mac pc headphone jack to 1/4" line in input
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
Sep 25, 2011 | Samson New Samson Mdr-1064 10 Channel...
I have a beringer sx3242fx, i need to know the best compatible amplifier to use my samson speaker that pushes up to 500 w
Almost any amplifier will work so there is no "best"... Just make sure the amp RMS rating is a bit below the RMS rating of the speaker for safety of the speaker. A QSC GX5 would be a candidate. You would use one side of it for each speaker if you have two, or use only one side for a single speaker. A lot of pro's seem to use these amps. USE BALANCED interconnections either XLR or TRS cables AND for sure power the amp and the mixer from the same receptacle... it often means running an extension cord like the pro's do to avoid ground bounce noise AND damage to the equipment.
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Txm20 samson ... unit wouldnt turn on... where is the fuse ?
if its not right next to where the AC power plugs in, or part of the power plug itself ( lil notch in cable recepticle that will allow it to slide out ) then it would have to be inside the mixer on the power pcb. ( the board the power cable connector is soldered to)
Aug 31, 2011 | Samson TXM20 20 Channel Powered Mixer,...
How do i hook up my mixer to a samson s.com plus compressor
Use INSERT cables to insert into the MAIN's. This will compress the whole level going to the mains.
Aug 04, 2011 | Samson TXM16 16 Channel Powered Mixer,...
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
The audio kept cutting in and out while using the Samson Stage 5T 3-in-1 Headset Wireless. It lost audio for about 30 seconds at a time. At the time, it was connected to a Samson MR 1064 Mixer that was...
Mar 28, 2011 | Samson Stage 5T 3in1 Guitar Lavalier and...
How do i connect dis mixer to another mixer?
First of all a link to the manual:http://s3.amazonaws.com/samsontech/related_docs/XM910_ownman_v1.pdf Have a look at page 14, 9. Go out of MixOut ( line level ) into any line level auxiliary inputs left and right on the other mixer. You didn't say what the other mixer is so this is the easiest. What you will have is a sub mix of everything plugged into the Samson controllable by the controls for the line in you are using on your second mixer. There are other options which you should be able to discover by reading your manual for the Samson and the manual for the other mixer.
Nov 07, 2010 | Samson Xm910 8Channel Powered Mixer...
Samson Xm910 8Channel Powered Mixer 900watts Logo
308 people viewed this question
Top Samson Music Experts
Vernon Taylor
Bernie Scott
Level 1 Expert
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
